Current Sailing
That's a very good question. Many of us are "experienced enough" (i.e., old f*rts!
), who sailed around off the coasts before even Loran (gasp!
). Most of us came back. While I didn't have an RDF, I did have a portable radio which I used when off the coast of California to check one line of position from the radio towers in San Francisco. Since I never was out of site of land, we actually, as was properly said, were PILOTING, not navigating.
If out of site of land, currents usually don't change very much, at least out here off our coast, and tend to trend to the south at up to one knot, not reversing.
Current sailing, however, in other places, like off the coast of Maine, can be quite tricky with the impact of all the rivers plus the normal tidal changes and associated impacts on currents.
Most of those are, however, pretty well known and documented. So, the answer is to learn how to do what IIRC Chapmans and Duttons call "current sailing" including all the factors you mentioned.
It's truly challenging, and very time consuming. It requires a LOT of planning ahead.
It's also very rewarding. I remember a trip outside the Golden Gate in unusual down-on-the-deck fog where I sailed without any instrumentation other than compass and speed and contours from the Gate along the south side (i.e., Baker Beach) to Mile Rock. I "hit" Mile Rock on the nose, almost literally!!! I was glad I "found" it and also glad I wasn't going much faster!
That was on the last of an ebb.
I then turned NW to find the next buoy across the shipping lane, which I checked by VHF and VTS as clear of shipping.
I also "found" that buoy at the start of Bonita Channel and Four Fathom Bank on a building flood, by compensating my heading with the drift from the new flood and the boat's leeway.
The wind was steady and I was running a full main and a 110 jib, so other than the ocean swell and slight wind waves, it was a glorious sail.
I also learned that there are *********s out there who use their instruments to go from waypoint to waypoint on autopilot with no lookout!!!
Big 40 foot sportfisher appeared out of the gloom at 20 knots! Never even saw me.
I now, as most advise, offset all waypoints to make sure those guys are at least a 1/4 mile away.
It was a great adventure.
I applied what I'd learned. In my case from Chapmans and Duttons, but Rich is right, learning in a class from the Power Squadron is a great idea, too.
I appreciate the instrumentation and finally got a Loran and then eventually a GPS.
A number of years ago I removed the old Magellan Loran 8000 from our boat (1986!). I shoulda saved it as museum piece - it looked like something from a Pentagon garage sail.
I think learning navigation is fun. Using it is more fun, 'cuz it means you're out on your boat! :dance:
And, it's handy safety tool to have, too.
KG,I've wondered about "Dead Reckoning." The way I've heard it used sometimes amounts to; "Well--I reckon it must be over there!" Seriously, for how many hours of travel, at say 6.5 kt, should one trust a DR plot? If you're updating your position plot every hr w/ GPS (until it fails) you'd have a baseline for drift and set "behind you!" But then the tide reverses during a new moon and you still have, say, 9 hr of travel after dark to destination with another tide reversal in the offing. Where would you really be at the end of those 9 hr lacking a fix on a lighted ATON? Now I realize that big-time ocean sailors can go days to weeks on DR (if they have to) and not be too far off when a fix is finally gotten. But what about when traveling along the coast where tides, currents, and local eddies potentially come more into play? How often does anyone practice with the GPS TURNED OFF? My guess is hardly ever to never b/c the position up date is continuous while the GPS is working--no need for DR plotting until it STOPS working. Whereas in the old school, one had to maintain DR plots between fixes b/c they could be gotten only one or two times a day, maybe, unless passing within sight of charted landmarks, etc.
