I understand that I should be able to start the M25XP engine off of one battery.
I have yet to be able to. I would very much like to be able to run off one battery and use the other as a backup.
I replaced the 4 year old batteries that came with the boat with brand new G27 deep cycles (the most "deep cycle" they can possibly be). and aside from not having a completely bad battery like I had before, there's no real change with a charged up single battery being able to start the engine.
I put a meter directly on the battery, and another one directly at the input of the starter motor (not after the solenoid) and cranked the motor. There was almost a 2V drop between those to points during cranking. So, at the battery while cranking I'd get an average of 11V, at the starter it was about 9V average. At rest they measured the same.
I then put a meter between the NEG of the battery and the engine ground and saw just under 1 V while cranking.
Then, I put a thick jumper cable between the NEG of the battery and the engine ground and saw no difference with the above behavior.
I put the jumper cable from the POS of the battery to the INPUT of the starter solenoid and saw an increase in over 1V at the starter and the engine was able to start. I then re-tested by jumping the NEG to engine ground and starting the motor, and it was a no-go.
So, it would appear that my positive connections from the battery to the starter are not as good as they should be. Next, I'm going to measure the OFF/1/B/2 switch.
----On a not-so-funny side note, earlier I had tried to turn on the hot water heater (110V) and noticed it wasn't working, so I pushed the reset button on it, and while I was doing all of this battery testing the hot water hose exploded under the rear berth and scared the crap out of me. lol
