heat exchanger sea water and antifreeze
Jun 12, 2013
213
Hunter 40 back creek
I have an Oday with a Universal Diesel motor and recent purchase. attempted to start the motor and when i did the impeller in the pump was sucking the water out of the bucket but when i looked closer one end of the water/antifreeze manifold/heat exchanger had blown off the left side end looking in from the engine access panel looking aft! Can this be fixed or soldered or do i need to buy one? where would i find one such part?
Jan 27, 2008
3,092
ODay 35 Beaufort, NC
What O'Day boat is it? Is it your raw water heat exchanger that failed or is it the exhaust manifold/antifreeze coolant tank? Any pictures?
Jun 11, 2004
1,952
Oday 31 Redondo Beach
Is it a cylindrical heat exchanger? If so this may be what you need. The end caps do crack some times but I'm not sure what you mean by blown off. It would help if you tried to identify your engine.
http://www.marinepartssource.com/pr...cat3=0&Category=Heat+Exchanger+End+Plate+Kits
11,772
Sounds like you had a freeze up... Who winterized the engine?
