Anyone know how to access these fixtures to swap bulb and or replace with LED's
Only want to replace the bulb not whole fixtureI tried that change also, but on the Beneteau parts site you can buy new LED fixtures that will probably fit the same mounting holes. Mine did.
So did I- at first. Then, for only 17$ for a 4-LED fixture, i'd rather switch than fight. Part # 461140Only want to replace the bulb not whole fixture
I was onboard my 331 today and noticed one of my swivel lights had come apart. Were you able to replace just the light and lense. If so what part did you use?That's a little different from my 331's swiveling fixtures of that type, but *as I remember it*, the "panel" to the left--the side without the switch--unclips and gives you access. I replaced all of the bulbs on those little fixtures with LED replacements from marinebeam.com a couple of years ago, so you'd think I would know for sure but...
