I'm looking for suggestions on plugging through holes.
is there threads on the other end if so get a bronze pipe cap and some pipe dope and just cap it off ...since it is out of the water you could also remove the fitting and glass it closed with some cloth and resinI'm looking for suggestions on plugging through holes.
I removed all my through hulls and glassed over them. The first one was scary pulling it out and seeing that hole in the bottom. After getting over thefirst one the other two went fast and easy. I don't like the idea of holes in the boat. The swing keel cable hole is the only one I have that's below the water line and I still don't like that one.I'm looking for suggestions on plugging through holes.
Thanks DaveKen;
Most folks would stuff glass and/or epoxy in the hole which is not a very good way. I would have cut out the ragged glass and then bevel the hole at a 45% angle outward or from the inside to the outside getting clean glass. Then on the inside of the hole, I would take a piece of cardboard with two layers of glass with resin on it and resin applied to the inside hold with a string in place, I held that in place until it held which give you a base to work with on the inside. Then I would start laying layers of glass with the first one the size of the hole and each successive layer a little larger to adhere to the beveled edges. If you do not have a resin roller to roll the air out and smooth the wet glass down, you can tip it with a brush dipped in acetone. You will probably have to do this a few times if the glass is on a side and not flat. Once done, spray paint over the glass and sand smooth. where there is paint left, are the valleys and you will either glass or add epoxy. either way, use a fine two part epoxy to fill the small holes with and wet sand. then onto painting with barrier coats and so on.
It's interesting how the sequence of circles of cloth applied has changed. When I did my first through hull closure about 20 years ago the process recommended was to apply the smallest circle first then next on out to the largest covering the whole shebang.
I read someplace it is stronger because you are trying to press a larger section through the smaller hole but I also read it allows more fibers of the inner most patch to be exposed water. I did mine like you described...smallest to largest... it seemed to lay in better... also I did both sides of course. To get my patches started I made a small 1/8 inch thick epoxy "plug" to fit the hole exactly...I sanded it down to match the hole and tap it into the middle of the beveled hole with a pencil. It was just big enough to hold itself in by friction, epoxied that in and let it dry first. This gave me a good base to start layering the pieces of matt and glass in.Now West and others say reverse the process, largest first! Now only the largest has the mechanical bond, admittedly a larger area, but I don't see how this is stronger then the prior sequence.
Has anyone actually done strength tests?? If so could you provide a link to the science, or at least the logic, behind the change. Thanks
I seriously hope this is an early April Fools Joke.Something stupid simple! Measure the hole, then buy a plug that has a washer an a S/S bolt and a wing nut. Make sure the plug in slightly larger to make sure it is tight after you tighten the wing nut, Walla! Do it from inside or outside. Your welcome!!
My reaction, too! My first thought was, "You have GOT to be kidding!"I seriously hope this is an early April Fools Joke.
That would work...as long as the boat is never put in the waterSomething stupid simple! Measure the hole, then buy a plug that has a washer an a S/S bolt and a wing nut. Make sure the plug in slightly larger to make sure it is tight after you tighten the wing nut, Walla! Do it from inside or outside. Your welcome!!
I believe that's a plug for a leak in a water heater tank?Something stupid simple! Measure the hole, then buy a plug that has a washer an a S/S bolt and a wing nut. Make sure the plug in slightly larger to make sure it is tight after you tighten the wing nut, Walla! Do it from inside or outside. Your welcome!!
