$25 Oil Filter!!
rfrye1
Jun 15, 2004
589
Hunter H376 San Diego
Ok so I go online and find a Yanmar place and order an OEM oil filter for my 3JH2E for like $10-13. I get a reply telling me I have to go thru my local Yanmar dealer in San Diego. So today I stop by QMC in SD and the guy charges me $25!
Seriously? My Porsche oil filter is only $9.
Bob.
Jan 30, 2012
1,150
Here is a fix.
Go to Wix Filters on-line, look up your motor in the off road section then go purchase that Wix number at your local auto parts store.
If you purchase at NAPA the NAPA part numbers are nearly identical to Wix numbers (they will be branded NAPA Gold - but they are all Wix.)
Here is the lead for your motor
http://www.wixfilters.com/Lookup/Applications.aspx?Section=4
Charles
Dec 2, 1999
15,184
I just saw the filter for $8.95 on the internet (mid west dealer)
Check with Boatswains Locker. They are distributor for your region.
Jan 6, 2010
1,520
I simply go to NAPA auto or similar stores. They have catalogs if you give them the OEM part number, they have a corresponding model# that will work.
Your engine doesn't care who made the filter ,only that it is the correct replacement.
If your engine is out of warranty, it's a non issue.
CR
May 4, 2005
4,062
Bob.
OT:
Where do you get a p-car filter for 9 bucks? stoddard? pelican?
there is a difference in the factory filters. it has a pressure relief valve, to keep supplying oil, even if its totally clogged.
Aug 16, 2006
281
Ericson 32 Oregon coast
There are some items that are best as OEM. Oil
filter is not one of them. I can actually see the $9 Porsche filter although I'd probably get a good aftermarket one for that if it wasn't under warrantee.
rfrye1
Jun 15, 2004
589
Mr Bill
FWIW. My 911 is 28 yrs old so my parts aren't too bad. Try AutoHaus.
Bob
