Selden Bowsprit
Hunter 260 Lake Carlyle, Illinois
Has anyone installed a Selden 072-072-70 Aluminum Bowsprit on a Hunter 260? We're hoping to do this on our Hunter so we can have a furled asymmetrical spinakar.
Tom Grass
Creve Coeur, Missouri
Kermit
Jul 31, 2010
5,713
Good luck with the project. Let us know how it works out and post pictures. Better yet, invite us all up for a rendezvous sometime!
Will do (maybe in the North Channel this summer). This weekend going over to the boat (boat's out of storage) and attempting to see if I can find areas to install the necessary Brackets for the bow sprit on the foredeck. I cannot use the anchor locker cover and I must have access to the underside of the deck for backing plates. Stay tuned.
Oct 10, 2010
269
Hunter H260 Gull Lake
I may be in for the North Channel. I'll be in Ontario this summer. What dates are you thinking?
We're planning on sailing with the TS/A (Trailer Sailors) organization. This year they (we) are launching at Little Current around July 18th - we'll be pulling out around August 1st. There will (historically) be around 30 to 40 boats - all trailerable on the cruise. I've attached the facebook link to the TS/A group. Hope we see you.
https://www.facebook.com/#!/groups/503731162986282/
-na -NA Anywhere USA
to access the forward section, remove the triangular panel held in by screws in the v berth. It is tight fit so be careful. There you will be able to install backing plates. Suggest using small drill bit first to make sure before the big bit.
Nov 8, 2010
11,386
Good luck with that one! I mounted one on our First 260, which has a much larger foredeck the H260. I was shocked by how limited I was in mounting choices.... the pole having to fit around the pulpit, the tip having to be on the centerline, and the back of the pole in a mountable location (not on the anchor locker door!). Made it work, just.
PS that pole is for sale if anyone is interested. Used maybe 10 times.
Pole for sale
Please supply details regarding the pole that you are selling (brand, model #, size, condition, price). Why are you selling this pole?
Could this item be mailed to St. Louis?
Please also supply details about where it was located on your H260.
Tom and Tracy Grass
Creve Coeur, MO.
Nov 8, 2010
11,386
Tom and Tracy Grass
Creve Coeur, MO.
Its a Sparcraft 70mm pole. I am selling it because we now fly our asyms exclusively from our spinnaker pole. It is in perfect shape. Very very high quality. We just never use it. Will sell it for 75% of best possible internet price. Its UPS shippable. We had it on our Beneteau First 260, not a Hunter 260.
Ref. Sparcraft Aluminum 54810701600
ø tube (mm)
ø 70mm (~2-3/4")
Length(feet)
5'3”
Max unsupported Length(feet)
2'7”
Suggest boat Length(feet)
25-33'
Kestle
Jun 12, 2011
702
MacGregor 25 San Pedro
Good luck with that one! I mounted one on our First 260, which has a much larger foredeck the H260. I was shocked by how limited I was in mounting choices.... the pole having to fit around the pulpit, the tip having to be on the centerline, and the back of the pole in a mountable location (not on the anchor locker door!). Made it work, just. PS that pole is for sale if anyone is interested. Used maybe 10 times.
Pm me please on the sprit...
Jeff
Update on Bowsprit Install
This weekend we got the Selden Bracket successfully installed on the foredeck of our H-260. Very tight. Was especially fun down in the v-berth tightening the bolts/washers beneath the deck. Thanks Dave for the tip!
Stay tuned.
You have mail...
