Adding sail trim controls
Mar 30, 2013
700
I've been upgrading the sail trim controls on my '76 Cal 2-27 kind of one piece at a time as I can afford it. Don's book has inspired me to try to get the most out of the boat that I can.
I'm running a hank on jib which while I like the "easy" of a roller furling jib I kind of like the flexibility of a hank on a little more
Anyway, so far I've added a mainsheet traveler as an upgrade from the single point in the back of the cockpit, ran my main and jib halyards back so I can work them from the cockpit, already had a boom vang, latest upgrade was a pair of ST winches that are more to help me single hand than a direct upgrade for sail controls.
My next couple of options are adding a Cunningham and a back stay adjuster, still trying to decide which will get me the best bang for my buck as the budget won't allow for both at the same time.
A backstay adjuster I can find-
(one example) http://www.harken.com/content.aspx?id=3896
But while I've found a few fuzzy pictures of Cunningham set ups I haven't see anything that really shows how one should be set up.
Anyone have any clear pics of a Cunningham rigged up?
Nov 8, 2010
11,386
A good cunningham system provide enough purchase to apply the pressure with a hand load. This means a 4:1 to 12:1 system that can either be worked at the mast, or be run back to the cockpit. For your size main a 4:1 should work. A simple system looks like this.
A set of fine-tune controls will work best with sail in good shape. The sails on your boat look original and rather tired. It might be wise to save up your pesos for some new ones.
Jack's right, although many cunningham setups do not always need that much purchase. I had just that block setup on our boat until the top block (an expensive Lewmar) died in the sun. I removed it and the lower blocks and the system still works to tighten the luff just fine, and ours is a bigger boat than yours. All it takes is some line run aft.
Garhauer also makes a nifty backstay bridle.
700
I suspect the sails are original to the boat and new sails are on the list but not in the budget, yet. The PO sent them off to sailcare and spent quite a bit of money on them but I'm not highly impressed.
Nov 8, 2010
11,386
Are you sure your mast can tolerate the bend?
On a masthead boat like the Cal, a backstay adjuster does not bend the mast. It attempts to pull it backwards, which it cannot do because unlike a frac boat the forestay is attached at the same point at the masthead. It does however tighten the forestay and thus reduces forestay sag. Thats the reason for the adjuster.
It also has the side effect of trying to push the mast out through the bottom of the boat. Failing that, it wants to fold the boat in two!
Nov 8, 2010
11,386
I'd guess so too. The narrow panels sewn on the diagonal give them away. Hood developed that technique in the late 70s but it fell out of favor over time. Sails have not been made that way for 25 years.
Oct 2, 2008
3,811
Pearson/ 530 Strafford, NH
I looked back at your previous post and would ask if you thought a different headsail would be worth while. Your jib looks a to be a working size for windy days. It also seems like you had enough halyard tension on the main so I would omit the Cunningham or just use a line with a hook through the cringle and tied to the boom. Just my thoughts.
All U Get
Here's the hardware hook. http://shop.sailboatowners.com/prod.php?14062/
6,243
S2 9.2a Fairhope Al
my cunningham is like the pic Jack posted ..it used to be 2 part but i felt that 4 parts would be easier to use so i up graded
Oct 26, 2008
6,277
Catalina 320 Barnegat, NJ
I favor the backstay adjuster. When the head sail sags in higher wind, the helm gets real heavy. Adjusting the backstay tension improves the handling substantially. Masthead rigs are driven by the head sail. I think you will find more benefit in improving the shape of the head sail than the mainsail. I like that bridle that Stu displays ... much better than mine. Do you have a split backstay?
BTW, Sailcare does a great job at cleaning the sails, and the finish makes them crisper (seemingly like new). But they can't do anything about improving the shape of an old sail, unless you specify that they do some trimming, which isn't exactly their forte, so to speak. A sailmaker can help, but at the end of the day, the need for new sails is inevitable.
Jun 1, 2004
8,196
Just me and my opinion.... but if your mainsail already has a Cunningham cringle, that would be a very inexpensive upgrade. You can get it done with two bullet blocks, the lower one with a becket... some attachment hardware, strap eyes and self threading screws.. for the lower block and the mast connection.... perhaps a fairlead to guide the line aft and a simple jam or vee cleat. Less than $60 if you if you stick to the correct size hardware. If you want to go with 5/16 line, which is more than adequate. You can save some money on blocks if you go with 1/4" line and use the stainless/acetal sheave type utility blocks... but the Harken 29mm bullet blocks will serve you well and are affordable.... the blocks are $14 and $17, the clamcleat is $9, at an online competitor...
Mar 30, 2013
700
Thanks guys.
The main already has a Cunningham cringle and after seeing what I need the expense is pretty minimal so that's pretty doable quick and cheap, can't hurt.
My backstay is a single wire so the bridle system won't work.
I'll walk the docks and see what is at the marina that I can emulate.
I'm gonna bite the bullet and move new sails further up the list and reevaluate the toy budget to see what I can come up with. Ought to be maybe less for a new main than the pair of Lewmar 30 St winches I put on last week ;).
Oct 26, 2008
6,277
Those winches are a very nice addition!
Mar 30, 2013
700
The new winches are much nicer to work with than the old Barlow 22s that came with it. the old Barlows work OK but a two handed operation. I single hand 90%+ of the time.
Other Catalina 30 Tucson, AZ
A jib cunningham is a nice and simple unit to install. I used a small soft vang that Garhauer put together for me.
Dec 4, 2008
264
Other people's boats - Milford, CT
On a masthead boat like the Cal, a backstay adjuster does not bend the mast. ...snip ...
Just a point of clarification. For lots of masthead boats, the backstay will bend the mast. Most of the boats that I crew on for races are masthead and they all can create mast bend by cranking on the backstay.
I haven't had a boat fold on me yet :)
Nov 8, 2010
11,386
Can you explain to me how that happens?? To bend the mast the masthead has to move backwards. That is impossible on a boat where the forestay is attached to the same part of the mast as the backstay. Like the masthead.
Fractional boats bend the mast by having the mast bend around the forestay attach point. Anything above that points bends aft, anything below bends forward.
I've owned racy masthead boats; we bent that mast with an adjustable babystay.
Regarding folding the boat.. ask someone that owns a big masthead rigged racing boat. Often when they crank on the backstay hard, you cannot open or close doors downstairs. One guess why.
16
Catalina 22 Portland Australia
cheap solutions to sail control
Hi Larry
A cheap way to get back-stay control would be to shorten your existing stay and install a cascading pulley system.
I recently got a new set of sails for my Boomaroo22(catalina22) from fareast sails in Hong Kong. Fantastic sails and service and the more you spend the cheaper it is. They have a discount system that increases with price .I ended up gettting my sails for half the listed price and that included freight.I have no affiliation with this mob but can't praise them enough. So much so that I am about to get a new suit of sails for my RL28.
Cheers John Rob Legg 28 Pinnaroo
Jan 31, 2014
4
Jensen Cal 28 channel islands harbour Ca
new sail
I'm not sure the dimentions are exactly the same, but i have a new mainsail i bought for my cal 28 flushdeck if your interested. It's been raised only 6 times.
Thanks guys.
