If I might be so bold as to throw my 2 cents (perhaps overvalued) in here re. masthead rigs and backstays. On a boat such as this with spreaders that are not aft swept cranking on the backstay will indeed put a bend in the mast. What happens is the mast is compressed and bends sort of like a recurve bow toward the bow. Initially is has the effect of tightening the headstay but with more tension the headstay actually gets looser as the point where the headstay joins the mast moves closer to the deck.
What also happens is that as the mast is bent it pulls the mid point of the main sail's luff forward flattening it out and de-powering it. This is a handy trick for conditions where the boat is overpowered but not so much that you want to put in a reef.
If you talk to the folks who made your boat they can give you the specs for mast rake and what is known as pre-bend. This is the target you aim for when setting up the rig before you put the sails on. As a sailmaker this is an important data set as the main sail luff should match this pre-bend. (Contrary to what many might think the main sails luff is not a straight line top to bottom.)
