replacing a 4000+ and st60 on a 29.5
Jun 12, 2014
25
does anyone know what I need to replace the above parts with, preferably raymarine. buying a 29.5 with non functional autopilot and depth sounder? please get back to me asap so I can source and price replacement parts.
Sailm8
Feb 21, 2008
1,751
Hunter 29.5 Punta Gorda
Where are they located now? I believe they would be a direct replacement in existing holes.
Jun 12, 2014
25
we are currently in negotiations to purchase said vessel. the boat is located in Maryland. I'm wondering which models would be a replacement for the non functional ones. the boat is a 94 model and the nonworking parts are from 04
Catalina 320 Dana Point
Under the assumption it's a wheel pilot, which part is non-functional ? You can replace the control head or wheel drive separately for $500 to $700, a new EV1 lists for $1599 complete. Earlier models had all the software in the control head, later models have a separate course computer with gyro. That affects what you would need to replace non-functional control head, the wheel drives are interchangeable. Often there is a mechanical problem with the drive belt or idler pulleys in the wheel drive. My "02 AP has just a fluxgate compass, no course computer or rudder reference sensor, later models have both, yours could have been either in "04.
You can check Defender and Fleabay for availability of parts new and used and approximate costs.
Hunter 29.5 Gloucester, VA
I have ST-60 instruments on mine upgraded from the ST-40 & 50 electronically they were pretty much straight replacements. The ST-50 wind vane reads a little off on the 60 head. I had to replace the 4000 auto pilot with the X-5. Not a direct replacement. Not real familiar with the new Raymarine instruments but I doubt they are direct replacement with out an adapter. Depending what is bad on the units parts are usually available on ebay
Oct 29, 2005
2,366
Autopilot you could buy the EV1 set. As for ST60, how about getting the ST60 Tridata.
If transducers still works it should work with the Tridata.
