Claygr, what you describe as a deep broad reach with main sheet in is about the situation we were in when I could not furl the jib manually. This is typically the maneuver that I use to furl the jib and it works OK in medium winds but apparently not in high winds.
I head to a broad reach when I want to furl the jib and let the jib sheet fly, the jib is now aligned with the wind with much less force but it is flogging around quite a bit and I try to furl it in fast to reduce the harmful effect of flogging, but not in the high wind case, could not furl it in manually. Had to finally use the winch.
thinking out loud, if I were to head downwind, more than a broad reach, and keep the jib still sheeted in, maybe I could let out the main enough to blanket the jib without heading too far down wind?? I agree that with the jib sheeted way out, I would have to head pretty much dead down wind for the main to blanket the jib but with the jib sheeted in, maybe not so far, maybe far away from an accidental jib situation.
Of course there is the problem that in a high wind, it might not be easy or possible to head down wind with the jib sheeted in. After all, it is a big jib (or else why bother to furl it in) and rather small rudder.
Also, of course, I will try not to get into that situation again.
