Fuel Lines
CYQK
Sep 11, 2009
610
beneteau first 42 kenora
Can you fab your own fuel lines with approved hose and AWAB clamps
or do they need to be crimped connectors for the coast guard
Thanks
Mar 6, 2008
1,522
Crimped connectors are not required. You can use hose clamps.
If you need or prefer crimped connections then truck supply / maintenance shops are handy and should be able to make you up a length of crimped hose to suit quickly and fairly cheaply.
CYQK
Sep 11, 2009
610
hose clamps are good for me not that much pressure anyways
Just wanted to check in on the ever increasing rules by beaucraps
11,772
You will want to make sure all your fuel hose is marine rated for diesel. The hose you will want will be rated as A1-15. The surveyors & insurers are getting very picky of fuel hose, fuel fill hose and fuel vent hose.....
CYQK
Sep 11, 2009
610
Thks Maine
Bought the good stuff ratings right on the hosr
