Changing to 6 volt golf cart batteries
Jan 10, 2015
130
. . Pensacola, FL
Maine Sail, do you have the "cigarette lighter" receptacle for these DC USB charger plugs wired directly to the batteries (fused, of course) so that they are always 'hot', or are they switched somehow?
dj2210
Feb 4, 2012
337
Catalina 30 Watts Bar
Since the subject is 6v batteries in a 2, 4, 6 bank, what chargers are being used? For instance when my C27 was converted to electric propulsion, I used four 12V AGM in series (48Vdc) and used a 4 bank 12V, 10 amp charger. I did a quick search and found very few 6Vdc multiple bank chargers, NOCO genius was the only one I found. So are you treating 2 batteries in series with a 12V charger?
11,722
It is a 12V bank so you simply use 12V chargers...
11,722
12V outlets should ideally be "switched" at the DC panel...
Catalina 380 16 Rochester NY
I've seen a lot of posts back and forth about battery choices, alternators, etc.
I did switch to 6v last year. I put 4 under the Nav Table.
As a house bank, it's tremendous!
Chris
