Over the past season I've been having a problem with the water faucets that wasn't there the first thirteen years I owned the boat. What happens is when I turn on the faucet the water initially comes out with normal pressure , no problem. But then after maybe 5-6 seconds of normal operation the water stops for a second or two and then BLASTS out spewing intermitantly for several seconds. It then goes normal again only to repeat the process. It blasts so hard that it will knock whatever is in my hand right out into the sink.
Anyone have any ideas on why this is happening? The pump seems to work fine.
Another issue is that for some reason when I fill the aft tank which sits higher than the forward tank the water from the aft tank will fill the forward tank. Somehow through gravity I assume the water is getting into the lower seated tank. Could this be due to a faulty switch valve that is used to switch between the two tanks?
Thanks for any help.
Joe Mullee
1983 Hunter 34
Joe Mullee
1983 Hunter 34
