1st of all, let me make it clear that I do not know anything about transmissions. Forward gear would not engage for the 1st 2 or 3 tries. I had it pulled and the mechanic could not find the label with serial # or gear ratio. I called Universal and was told that it is a Hurst (sp) 50-2R with a 2 to 1 ratio. He also said that it is no longer made and does not know if there are parts. I have a 2003 - 310 and the manual for the engine is dated 2001. I tried to read the serial #, but it is on the port side and not much room between the engine and the head bulkhead. I thought I read 2E8507F206. I was told the the E should be a #, but I must have misread some more digits.
Anyone have this issue? Anyone know of a replacement transmission or where to get parts for this one?
Thanks
Eric
Thanks
Eric
