Propeller
Richit
Jun 9, 2009
25
2 310 Coconut Grove, Fl
Hi all,
Does anyone have the stats on the standard 3 blade propeller used on the production 310 using the 25 hp Universal engine?
Specifically:
Bore size
Side (left hand or right hand)
Diameter
Pitch
Thanks
Richard Clarke
Opal Sea
KZW
May 17, 2014
831
From the marine survey on the 2005 C-310 I purchased in July 2015:
Prop Shaft: 1" dia
Prop: 3-blade bonze alloy, fixed blades
Measured Dia: 16"
Pitch: 9"
Manual says it is equipped with a a 15x9
CraigS
Jun 2, 2004
36
Catalina 310 Fort Walton Beach, FL
Mine came new with the 15x9 in 2001. Later changed to 15x9 flexofold and got rid of the prop walk.
Catalina 310 #147 Oakville Yacht Squadron
15 x 11 on mine. May be a little over-propped but I can do 3100RPM WOT; but smokes pretty quickly thereafter.
Cruise @ 2300-2500 so it's no big deal. With the 1100RPM idle it does make for a pretty good clip in harbour though.
Love Flex-O-Fold
Best investment I ever made.
Peter
Likes: All U Get
Sep 29, 2008
1,944
Catalina 310 #185 Quantico
Not to hijack the thread, but ...
anyone used that Kiwi prop? I kind of really dig the idea of the lightweight blades and the fact it feathers and it really simple, but the reviews are not so good. Would like to hear if anyone in our fleet has used on.
http://www.kiwiprop.us/
KZW
May 17, 2014
831
Rummalade, 2003 C-310, now residing in Tampa has a three blade one. The boat used to live in Bluewater Bay in the slip I currently occupy. The PO said he really like it.
Apr 5, 2019
44
Catalina 310 323 Brooklyn, NY
I know this is an old thread, but I am replacing the 2 blade 15x10 stock "sailor" type prop on my 2007 C-310 with a three blade for extra bite. Trying to decide between a 15x10 Sailor or 15x10 MP style.
Thoughts?
Sean
Likes: All U Get
:plus:For the Campbell Sailor. Talk with Kelsey. tell him about your boat, your motor and what you are looking to gain. he was extremely helpful with my new prop. Love it.
Dec 5, 2010
84
Beneteau 343 274 Niceville FL
Rummerful is back with the PO in the Niceville/Bluewater Bay Area and we still have the Kiwi...I love it, a bit more trouble to keep clean then the fixed prop but the speed gain and backing are worth it.
Sep 6, 2018
22
catalina 310 285 waikawa NZ
i am a kiwi with a kiwiprop great reverse response and seems to work well pitch adjustable one of the reversing rollers fell out the other day that was interesting no reverse at all quick visit to the travel lift
DaveJ
Apr 2, 2013
506
Sorry, did your
punctuation 'button' disappear? I had to read it twice to understand. But a good post.
Cheers mate
D
Deleted member 117556
Older thread here but indicates what I was told by Catalina which is that the standard factory issue prop for the 310 is a 15" 3 blade. Wondering what the tip clearance between prop and hull is for the many Catalina 310 owners who have 15" props? The diver who installed mine said that my clearance is minimal, like 1/4" at the most. Wouldn't that be the case for all 310's with 15" props? Thanks for your feedback on this.
That is an interesting question. If every 310 was built exactly the same, no modifications occurred at the hands of dealers or owners, and no changes due to use occurred, then yes, perhaps.
But the issue is not “aren’t all 310’s alike” but what is needed for your 310 to be properly powered.
You might ask what could be affecting your 310? My conjecture falls in a couple of areas.
  • The length of your shaft
  • The length of your strut
  • The size of your shaft
  • The measure of the gap by your diver
Pulling your boat for a short hang to measure for yourself would address most of these questions. On the other hand it is your boat and you can decide it is a non issue.
D
Just got my answer from Warren Pandy at Catalina. After my boat they most likely increased the engine size, lengthened the shaft and moved the strut back a few inches for more clearance. He said there might be cavitation and/or vibration but no damage. So I plan to run the new prop more and confirm initial results which were excellent. If any problems I can go to a 14" prop and solve it. Hull #1 strikes again!
Looking forward to learning how your experimentation develops.
Not bad for a SWAG....
