midship cleats
splax
Nov 12, 2012
694
Hunter 34 Portsmouth
Hello,
Winch covers arrived for Christmas ;) and I have used the jibsheet winches for my springlines, so I wanted to hear from those who have installed midship cleats on their 34. I have seen posts about cleats that attach to the jibsheet car track, but I don't think that is a strong enough option for a mooring cleat. I am interested in hearing about the experience from those who have used this option on a similar sized boat. :)
splax
Nov 12, 2012
694
nice upgrade
Looks good Terry ! How has it worked for you? Is there some toe stubbing or are they out of the way?
Dec 25, 2000
5,950
Thanks. No toe stubbing as they are pretty much inline with the toe rail. Very happy with their performance. Huge difference in solo sailing when it comes to docking and casting off. The midship line is always the first when docking and the last when casting off.
I added a portable boarding step to help getting off and on the boat due to the high freeboard. Easy to make, very handy, inexpensive and stores out of the way on the life lines when underway.
http://hunter.sailboatowners.com/in...mid=267&cat_id=45&aid=7550&page=article&mn=42
Nov 18, 2010
2,441
Catalina 310 Hingham, MA
We use the track mounted midship cleats. We have not found any issues so far except for an annoying squeak where the spring line rubs on the toe rail on windy nights. We have chafe protection there and have never had any line damage. We've ridden out two hurricanes with no issue. Hell. We had three nor'easters this year alone with winds in the 50-70 kts range. No issues with the cleat and I have closely inspected after each storm.
Mar 20, 2012
3,983
I agree..
The midship cleats attached to the track is as good as anywhere else... and much better than some ive seen
the pressure that is created in a springline by surge is a "shear" force, so assuming the track was mounted properly, and you use it as it it supposed to be used, there is very little chance of any damage.
Even a properly mounted deck cleat can sustain catastrophic damage if takes too much load in the wrong direction for too long of time.
As for the squeeking of the lines or chafing gear as it rubs the rail (including fenders) we have a spray bottle containing a solution of dawn dishsoap and water (about a tablespoon per pint) and when a line or fender starts squeeking, i wet the squeek area with the solution... it cures the problem even after it dries, or til the soap "lubricant" washes away...
splax
Nov 12, 2012
694
Can anyone suggest a source or brand of track mounted cleat for the H34 that fits on the jibsheet car track?
Mar 20, 2012
3,983
Presumably, you have a 1.25" track... google 1.25 midship cleat.... see what happens.
Jun 22, 2004
47
Hunter 35 St Augustine
Terry that is sharp looking and a nice install.....I have a 35.5 and no midship cleats has always bugged me for many reasons....the biggest being to have all of the lines going to just two cleats for and aft.....
Thanks for the pics and info!
Dec 25, 2000
5,950
Black Pearl
Thank you and you are most welcome. I used a bayonet saw to cut out the section of toe rail, smoothed with a hand file, then enlarged the two existing toe rail bolt holes for the larger cleat bolts. Best boat improvement ever.
47
By sharp looking I meant classy and factory like not cut your fingers sharp! Rereading my post it didnt come off that way......it may be on my list of improvements.
Sep 29, 2008
62
Hunter 37.5 Point Lookout, NY
I solved the problem a different way on my 37.5 which works well when I singlehand her, which is typical. At my dock I ran a length of nylon line stretched tight from piling to dock on each side of the boat and parallel to it. To this line at a location adjacent to the point of the boat's maximum beam, I attached a sturdy stainless steel carabiner good for several thousand pounds. So when I am gliding into the slip I just clip the windward carabiner onto the toe rail and can then make all other connections at my leisure. Admittedly it doesn't help when I tie up to a different dock, but it sure makes for easy docking at mine!
Maybe I'm missing something, but doesn't this require two people? One at the helm and one at midships to catch the carabiner.
