Thanks, I'm pretty worried. 1 not sure the terminal voltage but will check tomorrow 2. Smart gauge directly to the pos and neg terminals of the first battery in the three battery bank. with 28 inches round trip, very short run, with 16 AWG. 3. Red v sense to the battery right under the positive cable, 2/0, from the alternator to the battery bank, first battery again. 4. Regulator red/b+ connected to the alternator output, mating with the positive 2/0 cable that, again, runs directly to the bank pos terminal. 5. Regulator black runs directly to the negative post of the last battery in the bank, under the grounding cable that goes back to the engine block. That is where the alternator connects also, at the same bolt on the engine block. Temp sensors for all chargers in place and confirmed working.
