Cost of shroud on a 22ft sailboat?
Monaco
Dec 13, 2014
9
Tanzar 22 Tampa
I'm a sailboat newbie and I think that makes me an easy mark to take advantage of. I'm wondering what is a reasonable cost for a new side stay (shroud) for a 22ft sailboat?
My boat is a Tanzer T22 and the manual says 5/32 1x19 for diameter and 27"1 7/8 for length.
3,983
the problem you show will dictate that you need to replace them all.... the price will vary a LOT depending on where you buy them. Shop around. the cost per each from a local rigging shop should be around $30ea... its the ends and the swaging that cost so much... the wire itself is not very expensive...
Monaco
Dec 13, 2014
9
Tanzar 22 Tampa
What part is that little eyehole called?
Sep 28, 2008
922
Canadian Sailcraft CS27 Victoria B.C.
I would keep them to the designed size of 5/32". As the proper tension of rigging is a percentage of its breaking strength increasing the size will cause more load on each attachment point - the chainplates and mast tangs.
On a larger boat that was being re-rigged before heading offshore larger can make sense but everything else should be increased in size as well, particularly the mast tangs.
And I agree with Centerline - with the condition shown in the picture I would also suggest all the rigging is due for replacement, including turnbuckles. They haven't built a Tanzer 22 since 1986 and it is probably original.
Mar 20, 2012
3,983
Or maybe i misunderstood your question... to answer the question specifically as you asked it, the little eyehole is called the pin hole... or, the hole that the pin goes thru...
Jun 1, 2004
8,346
I'm a sailboat newbie ......
Read this: http://www.boatus.com/seaworthy/rigging/
Then study this: http://www.riggingonly.com/stdrig04.htm
Then search for local and online rigging services.... maybe start with the riggingonly.com ... but understand there are "riggers" who actually do the installation work... and "rigging suppliers" who simply build the hardware to your specs.... while you do the installation work.
Anyway, talk to some shops, get some quotes and decide what's best for you. A rigger will cost a lot more than doing the work yourself. You can even make your own rigging with swageless terminals.... but I suggest you do your homework, learn the language and you won't have to worry about sounding like a newbie.
Good luck
slaume
Feb 21, 2014
105
Cape Dory 30 C Noank
Get a hold of Rigging only, in New Bedford, MA. If you send then your original riffing they will do a fine job of making up a new set at a very fair price, and ship at all back to you. Great folks to deal with, Quality work, fast turnaround and fair prices. I Had a great experience dealing with them and have never heard a bad word about them from anyone, Steve.
Sep 28, 2008
922
I would think that there has to be a good rigger in Tampa, the po's home port.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
try SECO South in Largo its just down the street from Tampa ask for KEN..
Beneteau 323 Annapolis MD
its called a swedged eye terminal
West catalog, P 1003, it's called a marine swage eye. Actually, it might also be an "aircraft-type eye". Same purpose, a different shape, mostly depending on thickness. That's SWAGE- with an "A".
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
you are correct that is exactly what SC Johnson calls it also ...the terminal is the threaded end ...some days i forget which end is up lol and yes with an A not E
Mar 20, 2012
3,983
google search "open swage socket" and "closed swage socket"..... there are different types of swaged "eye" sockets, but be specific if you are going to talk to someone on the phone and it will be much easier to get some specific answers...
slaume
Feb 21, 2014
105
I think that the main point here is that the original poster is fairly new to sailing. If one fitting in your rigging has failed, you should not be looking at replacing only that shroud. Unless it was broken by some gross miss handling of the rig. All of the standing rigging should be replaced before the boat is sailed again.
You would feel pretty foolish if you were to only replace one shroud and then lost your entire rig, Steve.
Monaco
Dec 13, 2014
9
Tanzar 22 Tampa
It snagged on something as we were lowing the mast and broke.
