A newer one in good condition would not have broken unless it was the weight of the whole boat on it. It is not hard to see the corrosion in the picture.It snagged on something as we were lowing the mast and broke.
Replace all the rigging.
Looks more dirty than corroded to me. I don't see much evidence that it bent before it snapped, which suggests that it might have been a bit brittle. But then I don't know what kind of load was applied to it. My boat has the original 1986 standing rigging, and I keep telling myself I need to replace it all before something breaks. If only money was no object...A newer one in good condition would not have broken unless it was the weight of the whole boat on it. It is not hard to see the corrosion in the picture.
The wire should have pulled apart or even pulled out of the swage before it broke there... if it was in god shape, which it clearly wasnt.It snagged on something as we were lowing the mast and broke.
A terminal is any end fitting. A swaged terminal describes the way it is attached to the wire... there are hand pressed swages(as in a hand swaging tool) and machine pressed swages. There are many types of swaged terminals, including: marine eyes, threaded studs, marine jaws, marine toggles... etc.
http://www.suncorstainless.com/swage-terminals-1
There are also "swageless" quick attach fittings such as Sta-lok and Navtec Norseman.
http://www.pyacht.com/norseman.htm
Well, Tampa's a very strange place and whenever there's a holiday, they like to take that entire week off, so what happened was I already had a crew scheduled to sail on Jan 3rd, but SECO, SSMR, Paradise and Island Nautical all decided to turn Christmas and New Years into a 3-week vacation and being that Mac has no friends, he was the only one available.I'll stand with my original advice. You still have the other shroud to take to someone, reputable, and have all the rigging made up. From your description, Mac is just the kind of guy you were trying to avoid when you first posted here. You got some great advise and references from people on here and then chose Mac. There must be a lesson here and so far it will only cost you $155.00 if you go that way, Steve.
