I recently noticed that while sailing my prop shaft turns. If I put the engine in reverse(engine is off while sailing) then it does not turn. It does not seem to change my speed either way. Seems like if the prop shaft is turning always while sailing that it might wear the bearings eventually.
So my question is: Should I leave the transmission in neutral while sailing (shaft turns) or should I put it in reverse to stop it from spinning?
Thanks Mike
Thanks Mike
