The lazy jacks on my boat (H26) are set up as shown in the diagram and picture attached. I invariably have problems when I raise my fully battened mainsail. The battens tend to snag under the lazy jacks unless I am precisely headed into the wind and even then it will often snag. Currently the high point of the lazy jacks are well above the spreaders and just below the hounds (19' above the goose neck). I'm thinking to lower the high point down to the spreaders which will reduce the angle with respect to the boom and hopefully minimize the interference with the sail battens as the sail is raised.
Should I be able to find a lazy jack configuration that would allow me to raise and lower the mainsail without having to adjust the LJs? The way it is setup now I have to climb up to the foredeck to make adjustments.
Does anyone have any thoughts or recommendations before I start making modifications
