D
Deleted member 117556
Was wondering what boat speed most people make in a Cat 310 while under power at a normal cruising RPM, ie: not at full throttle? If your normal cruising RPM is 2,400 then what boat speed will you typically make without wind and current? Am asking because I have a different engine than all other 310's and cannot get close to hull speed. My typical boat speed at the high end of cruising RPM (3,000 RPM for me) is ~ 5.5 knots. Have a 3 blade fixed 14" prop. Thanks.
bob
bob
