I've recently added a new water heater to my 30 foot sloop (S2 9.2A). The original water heater was not connected to the engine, but, since the new one offered that option, I looked in my manual, found and removed the two plugs on the FWP and thermostat housing, and ran half-inch hose from them to the new heater. Yesterday I fired up the Yanmar, which started reasonably well considering the mid-40's air temp and 50ish water temp. Despite running it for nearly half an hour (mostly around 2K+ RPM, with and without the prop engaged), I was seemingly unable to get it hot enough to open the thermostat. When I first removed the plugs a month or so ago and put in the 3/8" fittings, I temporarily ran a loop between the two fittings (the heater wasn't yet in place), ran the engine maybe ten minutes, and was able to see, toward the end of the run, some coolant coming from the port on the thermostat housing. The weather was admittedly warmer, but I should think that a half an hour of running should be enough to get the thermostat to open. I've got a digital temp gauge bolted to the thermostat housing. It read about 135 degrees, max, during the run. I'd left the coolant cap off so I could add coolant as it started pumping through the hose to the heater. I don't think that ever got over about 80 degrees. I suspect it might've gotten hotter if I'd run it closer to idle, but I thought that wasn't good for the engine.
Is it typical for the thermostat to not open under these sorts of conditions?
Any recommendations on what sort of procedure I might follow to get it hot enough to open, rather than waiting for spring time?
I'll attach a shot of it when I just had the loop set up, for what that's worth. Once this is done, I promise I'm replacing all those hoses, cleaning the heat exchanger, putting in fresh, extended-life coolant, etc.!
Thanks.
John
Thanks.
John
