effective low amp fan for heat circulation
Nov 26, 2012
2,315
Catalina 250 Bodega Bay CA
Since I have many of the 3" computer fans lying about I decided to finally test one in my boat for heat circulation. They only draw .07 amps which is great. By installing one of these fans with air blowing down it does effectively circulate internal air throughout the cabin. High temp buildup was apparent near the overhead without the fan on, but, it dissipated quickly when fan was turned on. Any non fan heaters like a Mr Heater will work much more effectively with use of one of these fans. In my case it mounts beautifully right under the galley shelf behind the 1 burner stove top. Hope this helps some of you, Happy Thanksgiving! Chief
richk
Jan 24, 2007
495
Marlow-Hunter 37 Deep Creek off the Magothy River off ChesBay
outstanding! thanks Chief
Happy Tday
Rich
Feb 10, 2004
4,112
Hunter 40.5 Warwick, RI
Another use for these small computer fans
This is a 2" diameter fan that I cut to fit inside of a 2" PVC elbow. Connected to a vertical tube it pulls cold air from the bottom of my refrigerator and blows it across to the opposite side.
Very effective in promoting a uniform box temperature.
Mulf
Dec 2, 2003
400
Hunter 410 Chester, MD (Kent Island)
Question for Rich
Rich: Interesting fan idea. I currently use one of the camper variety that uses 2 D cell batteries to do that. Eats batteries. Does yours use the 12V boat system? How did you route power to the fan?
weinie
Sep 6, 2010
1,297
I tried using a computer fan a couple of years ago keep the air from getting stale on hot days when I wasn't around. What I found was that the only air that moved was in the very immediate vicinity of the fan. I didn't notice much of a difference and that was on a small 27 footer.
Feb 10, 2004
4,112
Bruce- Yes a 12V fan. Power taken from the 12V input to the compressor unit and the very small power wires routed along the refrigerant lines. It runs 24/7 when the refrigerator is powered up.
I originally tried the camper style fan to see if it would work. My design works much better because it pulls cold air from the bottom and shoots it across the top of the box to the opposite corner.
Mar 20, 2012
3,983
you can do the exact same thing but on a little bigger scale (larger tube and fan), to take the hot air from above the heating source and blow it outward down onto the floor.. a very efficient way the get the hottest air at the top down to the cold floor in the quickest amount of time...
the same method is designed into some homes with open lofts or high vaulted ceilings.
Nov 26, 2012
2,315
weanie: you need to install your fan better. The computer fans displace a lot of air for their size and frugal amp use. Chief
