Galley backsplash - the way I did it
Apr 21, 2014
11
Catalina 30 Alameda
Slider material
Coriolis, nicely done! I also like the mirrored sliders, where'd you get the material, please?
Really slick Chrisings- btw/ what thickness of lexan did you use for the backsplash (and what thickness do you recommend for the sliders?)
Nov 14, 2013
238
Catalina 30 MkI 1983 TRBS Westbrook, CT
The lexan is 1/4", not sure what sliders you are referring to?:confused:
Apr 21, 2014
11
Catalina 30 Alameda
Slider doors for galley storage along the port side (see pic) one of mine is cracked... I'm pretty sure they are 1/8" if the backsplash is 1/4". Thanks for providing food for thought - I'll probably copy your design!
238
Ah, those are the original doors on my boat. If you look back in this thread Coriolisbc replaced the doors with mirrored ones. Really nice looking too.
Nov 14, 2013
238
Chris, very nice!
One thought though. The acorn nuts might catch things on the counter when you're making dinner. A flathead bolt and a finishing washer would give you a flush fit.
Jim
Thanks Jim,
That is basically what is on the other side. My though was someone setting with their back to the galley might feel the nuts poking them in the back, hence my acorn nuts on the counter side. We'll find out in the spring if they get in the way. Pretty easy to swap them around.
Feb 26, 2008
603
Catalina 30 Marathon, FL
Thanks Jim,
Makes sense. Maybe a barrel nut on the counter side? Sorry, I'm an incurable tinkerer so I'm always looking to fiddle with the details :D
Nov 14, 2013
238
I like the barrel nut idea. McMaster-Carr perhaps?
Feb 26, 2008
603
Any good hardware store should have them.
You might even get lucky at Home Depot or Lowes. Look in the boxes marked "specialty hardware" on the hardware isle.
