Condensate Pumps
Sep 8, 2013
71
Beneteau Oceanis 45 Rock Hall, MD
Has anyone decided to just throw out their Condensate Pumps and drain their AC Units into the bilge? I've about had it with mine.
7,570
Alden 50 Sarasota, Florida
Use a Venturi tube to suck condensate out with the discharge water. Draining water into a bilge is never a good solution.
Mar 22, 2010
23
Beneteau 343 Panama City
I replaced my condensate pump and it was a pain and it is still working several years later but it would like a simpler solution when it fails again. From where did you get the Venturi tube setup? Or did you make it?
7,570
I made it from parts obtained from the local water bed store which sells it to fill/empty their beds. Total cost approx $15. There is a commercial variant called the Condensator which canbe bought for around $150 if you like to aide the economy.
Oct 3, 2008
325
Beneteau 393 Chesapeake Bay
My boat came with the Mermaid Condensators. They do work well. No moving parts to maintain. Just keep a fillter/screen in line and occasionally clean the Condensator itself. If I were to do it now, I would of course look into the less expensive option to make it myself.
