23 anchor locker drain hole sealant
Aug 9, 2011
49
oday 23 Toms River
Does anyone know exactly what flexible "sealant" was used to "seal" the anchor locker drain hose at the bow exit hole? I know the solution to the leak problem but was curious as to what was used originally. Thanks Roger
Pat
Jun 7, 2004
1,250
No idea, but wonder where it is leaking...? No problem with leaking anchor locker. Our
slip neighbors had horrendous problems w/their anchor locker on their Erickson 28...
Mar 20, 2012
3,983
the bow exit hole?... is there not a thru hull fitting that the drain hose attaches to?.... the sealant that can be used to seal under the thru hull fitting could be about anything... plumbers putty, 3M-4000, silicone, boat life, ect....
but the hose should not be glued into the exit hole with sealer.
Ward H
Nov 7, 2011
3,843
On my 25 it is a threaded stainless pipe nipple glued/epoxied into the hole in the bow. Mine loosened when I replaced the hose. I put epoxy around it on the inside to support it and used 3M4200 from the outside to seal the slight gap between the slightly recessed pipe nipple and the surrounding fiberglass. No thru hull there.
There is a thru hull at the bottom of the anchor locker.
Nov 5, 2010
99
Oday 23 Stonington, CT
I used a piece pvc pipe epoxied into bow hole, then hose clamped drain from anchor locker. Remember if this fails in heavy weather it can be bad. I check mine every season to make sure that short section of pipe is secure.
992
Oday 25 Gibraltar
I used a piece of 1/2" copper pipe that I flared on the outer end and pushed through the piece of wood that was in place on the inside, then clamped in place. Then I ran a section of tubing to the anchor locker drain.
