Johnson or Yamaha Outboard??
Apr 23, 2014
54
Irwin 28 Long Island
As it's built for a certain max weight, it should be able to handle everything you throw at it, within reason.
High-thrust prop included.
The main thing that I've read is the 4 stroke brackets are built a bit more rigid and tough to reduce the bracket swaying back and forth or flexing at all while motoring and taking sharp turns, or dealing with rough water.
But I'm going to go for it since the 71033 is a pretty beefed up bracket already. Wish me luck.
Feb 20, 2011
8,062
I think you'll be fine. G'luck.
At the risk of thread drift, I wonder if Garelick sells just the motor mount plate?
I've sent 'em an email.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
if you are worried about the motor jumping ship put a safety lanyard on it to tether it and secure it to the boat some kind of way to not enter fear with operation and go for it
Apr 23, 2014
54
Definitely going to do that.
OK, here is my last dumb question... :neutral:
My Irwin has a pretty significant curve in the transom. I want to put the bracket in the port quarter or corner for easy installation as I can get back there through my lazarette access easier then centered or starboard mounted.
However it will leave the motor bracket on a slight diagonal and not exactly pointing straight back off the stern. Obviously I can just steer or position the motor on the bracket to be pointed straight back but the real question is, will mounting it like this make a safety or performance issue? or worse, hurt the fiberglass.
caguy
Sep 22, 2006
4,004
Why not mount it in the center? There is less influence from healing in either direction if mounted in the center. I would have mounted mine in the center on my C27 but there is a center transom ladder that prohibited it. Since your rudder is tucked under mounting inn the center should not be a problem.
Mounting on the side of the transom should not pose a propulsion problem either. The only problem with it there is as stated earlier with a slight heal in high seas you prop will leave the water occasionally.
Apr 23, 2014
54
I cannot get under there in the center and I have equipment already in the center, so I have to mount it on the side. I am having an issue with the curve of the transom though so I have to figure out how to shim the bracket to make it sit flush against the transom.
Jun 1, 2004
8,346
It will be under weight, but will the high thrust be an issue? I'm very slow and gentle under motor so I doubt I'll ever push it too hard. Rough seas could be a potential issue too. Just weighing my options for the least headaches and best performance.
Hi thrust prop gives you more power, less top end speed. it's like a lower gear... the prop's pitch is less than what might be appropriate for a planning motor boat. Most sailboat out boards would be more effective, and more efficient, with a high thrust prop.
Nov 6, 2006
10,252
Off center is fine.. Most smaller, outboard powered boats have the engine off set for easier access.
Apr 23, 2014
54
Think an Irwin 28 with 7800# displacement will be fine with it off-center? I am going to make sure the bracket has a nice footing where it will be mounted, strong backplate on the inside, shimmed with high grade material so it sits flush, basically as strong as I can make it. I am thinking it will be good.
Bob J.
Apr 14, 2009
775
Sabre 28 NH
It's an interesting concept installing an outboard on the transom plus thinking of an electric yacht repower down the road. You could end up with the best of both worlds.
Apr 23, 2014
54
Thats the goal but it is a lot of effort and money to get there.
I am going through the mess of getting the outboard on there now. Hoping I do it right and dont damage the fiberglass at all. Then 2015 will be the year of electric for me doing the inboard upgrade. Hopefully it will work out and I can keep cruising and traveling while doing it all.
Ward H
Nov 7, 2011
3,843
My bracket is mounted off parallel to the centerline of the boat. Just means I need to turn the OB so it is parallel to the boat centerline, not square to the bracket.
Once thing to look for on the 2001 Yamaha. I had a 2002 with electric choke. Lots of issues getting it started. It had a critical starting procedure which if not followed, it would be very hard starting. The thin I hated was that when in neutral the throttle was locked from turning. This meant if it was struggling a little bit you couldn't goose the throttle to keep it running.
I was told by two dealers that if the electric choke failed there were no spare parts for it.
As I understood it Yamaha tried the electric choke for a couple of years and then went back to manual choke. My new T9.9 has a manual choke and which I rarely need to use.
One other thought which I think you are addressing. Since the stern of your boat was not built to support a OB, reinforce it well.
Feb 17, 2006
5,274
My thoughts would not be on the mount, but the glass the mount is attached to. It would seem that given a hard hit the weight of the motor and mount could damage the glass. I could be way out in left field here, but just a thought.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
i am thinking use a large backing plate on the inside to spread the load out some ....as for shimming the offset i would not worry much about doing that as you can set the direction of the motor to run straight ahead and lock the swivel in the tiller shaft in that position ..after all you steer with the boats tiller anyway ..most sail drives are set rigid so what would be the diff
Dec 3, 2013
169
HUNTER 29.5 PORT CHARLOTTE FL
Why not fabricate a wedge shaped spacer from laminated ply or a thick block of wood to position motor parallel to centerline? Coat w/epoxy and paint and
then install between mount and transom.
Ward H
Nov 7, 2011
3,843
A lot of O'days came with transom wedges which is exactly what your asking about. Should work well for you. Be sure to use long bolts and they go all the way into the inside of the transom and your reinforcement backing plate.
Pearson 26W Marblehead
outboard???
You have a boat with a displacement of 8000 lbs. This is heavy for a 9.9 hp outboard
I have a pearson 26W at 5200 lbs My 3 year old 8hp tohatsu pushes the boat at hull speed 3/4 throttle in medium air 10 kts the motor weights 83 lbs The old mercury 2 cycle 8hp that came
with the boat when I bought it needed full throttle to move forward against the same kind of breeze. My opinion: your trying to move a lot of weight with an old 9.9 motor. did you check
the transom specs Does the transom need beefing up I suspect you might need more HP to push the boat into a breeze in any kind of chop. Be careful! good luck
May 4, 2005
4,062
Unless I missed it, nobody asked about how long the shaft's of these engine are.
A common problem on most transom mounted ob's is they cavitate in a chopy seas.
So, when you are exiting a harbor, where its narrow and choppy, the engine can come out of the water, and you have no power... that's also bad for the impeller.
raising the main helps steady the boat, but its still an issue.
they work fine in flat water, but channels can be trouble....
I would want the longest shaft possible, even if it means going to a large engine...
-using vasoline around the sealing cowl cover helps waterproof it, if you have to lower it so much it goes under water...
-ymmv.
