The main thing that I've read is the 4 stroke brackets are built a bit more rigid and tough to reduce the bracket swaying back and forth or flexing at all while motoring and taking sharp turns, or dealing with rough water.As it's built for a certain max weight, it should be able to handle everything you throw at it, within reason.
High-thrust prop included.
But I'm going to go for it since the 71033 is a pretty beefed up bracket already. Wish me luck.
