Wind Instrument display not reading
Feb 22, 2013
25
Hunter 420 Passage Center Cockpit Marina Del Rey
My Raymarine ST60+ Wind display is not pointing to the wind although it is displaying wind speed. It was working previously, and yesterday I noticed it just pointing forward no matter the wind direction. The windex at the masthead is properly pointing to wind.
Any ideas how to start troubleshooting this? I admit I have very little understanding of how my instruments are all linked together.
May 1, 2011
5,567
Pearson 37 Lusby MD
DrBill, I just went through this over the summer. Both the masthead unit and the display were shot. Ended up replacing both.
Dec 2, 2003
480
Catalina C-320 Washington, NC
Mine was easy...not.
I had the masthead unit and instrument bench tested by Raymarine and they were ok. I messed around for a couple of years off and on trying to get it to work. I could never could get it to take the initial calibration and even though I could adjust the offset, it would never hold.... although it would always read wind speed accurately. I tried triple checking the set screws on the masthead cups to make sure they weren't slipping. I searched the internet rigorously but could not find a solution or the identical symptoms... Finally a seagull broke the wind cups and I replaced the masthead unit...it all works fine now and I didn't even have to calibrate...go figure.
Dec 5, 2009
80
Hunter 36 Hernando Beach, FL
I just went through the same problem. There is a easy masthead test procedure on the Raymarine Forum - Instruments section. You can apply an 8 volt dc source to the masthead wiring and measure output voltages for wind speed and port/starboard orientation taking the control head out of the equation.
Hunter 29.5 Gloucester, VA
You can also search here for the voltages you need. There should be a little junction box where the wires of the mast head unit hook together where you can check the voltages
Jan 24, 2013
39
Beneteau 49 Norfolk
Here's the link to the procedure and expected voltage. I had the same issue. Using this I was able to determine the fault was in the masthead unit. Good luck.
Www.raymarine.ning.com/m/discussion?id=6492755:Topic:43356
Jun 4, 2004
834
Hunter 340 Forked River, NJ
ST-60 Wind
I had the same problem year before last. In retrospect, the electrical and mechnical connections at the masthead were probably coming loose but I did not go up the mast to check. That fall/winter, my entire (loose) masthead unit blew away in hurricane Sandy and had to be replaced. The new unit worked right away.
So in keeping things simple, a check of the masthead connection collar might be advised before you start replacing things.
