zincs placement on the shaft
Mar 21, 2004
2,175
Hunter 356 Cobb Island, MD
Getting ready to replace the zincs and it occurred to me as to where on the shaft is the place? I usually place them about 8" from the strut.
Close to the strut, close to the thru hull opening, mid way. Wondering about vibration issues if really matters.
Or who cares?
Nov 6, 2006
10,251
Worst case for vibration is to put them right in the middle .. I usually try to get them closer to the strut but not so close a to affect the water flow into the Cutless.
Ted
Jan 26, 2005
1,280
zinc placement on the shaft
I read somewhere that the shaft zinc should be placed one shaft diameter in front of the strut.
Feb 26, 2011
1,440
Achilles SD-130 Alameda, CA
Anode location on a prop shaft is a really a non-issue. Put them wherever you like, as long as they aren't in contact with the hull or impeding water flow to the cutless.
NYSail
Jan 6, 2006
3,187
Beneteau 423 Mt. Sinai, NY
When I put my zincs on the shaft I always keep them far enough away from the strut just in case for some crazy reason I have to uncouple shaft and slide away from engine. Hate to have to do something and shaft won't move because of zincs...... One never knows........
Dec 14, 2003
1,450
Claude, that would be true if you had a vibration to start with because the added weight would help create a greater whipping action . Otherwise, the anode is equally balanced all around the shaft and has no impact whatsoever. Like Jim, I place mine about 6 to 8" from the cutless and have had no vibration at all. Claude
1,096
CS 30 Toronto
I put it about 1" before the strut because someone I know experienced a drive coupling disengage at reverse. The shaft went back and open up a 1" hole for seawater. The prop jam on the rudder to make towing difficult. If the zinc was able to prevent the shaft from leaving, there would be no drama.
On the same topic, did you check the torque bolt on the coupler lately? Some installation only has a small Allen screw. Scary indeed.
When going forward, the shaft transfer the torque towards the transmission. When reverse, the shaft try to pull out of the coupler.
Mar 21, 2004
2,175
Thanks everyone. looks like a non-issue.
Was just wondering about this...
Boat came out of the water yesterday.
Dec 19, 2006
5,836
Hunter 36 Punta Gorda
What's Up
So what's the plan for heading south and when you plan to be over on the west coast of Fl.
I am getting my boat ready for our 3 week cruise with PGSC up to Tarpon Springs and will be heading out around Nov 4,the boat needs a good cleaning
and put everything back together after being up NY all summer and back again Sept for my MOM but everything is good and doing all my polishing and waxing as I put everything back on.
Nick
