Head or no Head?
Aug 3, 2012
2,542
We are considering mooring our boat and spending some short vacations aboard over at least the next few seasons. We will row out to the mooring from a public boat ramp which has no bathrooms, and cruising over several days seems to necessitate a method of dealing with natures calls.
I am considering adding a head to our Oday 272. Right now, it has a portapotty which we have never needed to use, having been lake sailing since moving into bigger boats.
Any thoughts or advice and experience is welcome on this subject. To do or not to do? What kind of equipment is recommended? What to avoid? I did read a nice article on the subject. http://www.marine-surveyor.com/newsletters/9910.html
It is a little dated, but I found it helpful.
Thanks,
Andrew.
Aug 22, 2011
1,113
We spend extended periods on our boat on inland lakes. The boat originally had a portapot with a tank that you carried off to dump (eww). I am not interested in plumbing dasbOOt for a marine head. Since most lakes we visit have no public bath or pump out/disposal facilities a solution had to be found - especially for the admiral.
I tore the portapot apart and converted it into a double duty bag/bucket system using most of the parts from the old portapot. It works out great except their is occasionally an odor when it is opened for use. We think its the best compromise for us. In the duty business there is no free lunch.
ps; I stole a bunch of ideas from Sumner and Ruth on this subject.
Oct 26, 2005
2,057
- - Satellite Beach, FL.
Having installed full MSD systems (head, holding, hoses, valves, thru hulls, pump out deck fitting, macerator, etc) on a couple of my previous boats (35' and 41'), I can tell you it's expensive, a lot of work (PITA type) AND these systems have to be maintained.
I'd make do with the portapotty. Simple, legal, cheap and not much to break. Use the chemicals and the right TP.
kito
Sep 13, 2012
2,011
1979 Hunter Cherubini 30 Clemmons
I went with aThetford (msd version). It has a built in 5 gallon holding tank that can be pumped out. I figured it will hold enough crap before being pumped out. It is also hooked to a "y" valve and a manual pump to use in legal waters.
Sumner
Jan 31, 2009
5,254
....and we stole it from someone else ;). As mentioned other than the odor (which can be reduced -- use a little of the stuff West Marine sells for this in the bag.) during actual use it worked out great and freed of a bunch of room on our small boat.
With two of the 5 gallon buckets with the snap-on lids for storage we went 7+ weeks on the water without having to ashore to dump once. We also used the same system on the Endeavour when we were moving her and had planned on doing the same once we dumped over 3 miles out the last time until we returned to the boat yard so the holding tank would be empty there.
I know a lot of people 'turn their nose up' at using the bags, but no hauling that porta-pottie into a bathroom to dump and then try and clean every 3-4 days and having to make your sailing schedule around those trips. When the trip is over take the $2.50 bucket to a dumpster and you are done.
More on the our site here...
http://purplesagetradingpost.com/sumner/MacgregorTrips-3-Powell09/09-10-16-Powell-09.html
Sumner
[FONT=Arial, sans-serif]============================
Our Endeavour 37
Our MacGregor 26-S Pages
Mac-Venture Links
[/FONT]
Oct 26, 2008
6,432
Catalina 320 Barnegat, NJ
If you are using your boat exclusively in freshwater, it means that there is no legal discharge anywhere you are going to be. That said, it seems that you are looking for greater capacity than you have with your porta-potti. Perhaps you don't like having to deal with the disposal (I don't blame you). If you have ready access to pump-out facilities, I don't know why you can't simply install the toilet with an adequate-sized holding tank without going thru the effort of installing a thru-hull discharge to the lake. You would still install the deck fitting for pump-outs. If the boat was ever moved to salt water, the thru hull could always be added later.
That's essentially how we use our toilet and holding tank. There is no use for our thru-hull even tho it came with the boat. We don't really have a need for a toilet and we infrequently pump out our 10 gallon tank based on our very infrequent use. I think that you might want more capacity if you stay out for longer periods than daysailing.
kito
Sep 13, 2012
2,011
I have a waste thru hull on my setup but will not connect it from my hand pump until I move it to the coast. The bag in the bucket pics got me thinking that I could hand pump into a bag in case the built in holding tank gets full before pump out.
Beneteau 323 Annapolis MD
Perhaps a porta-potty with more than one tank that you could switch out when it is full?
Pearson 26W Marblehead
head or no head
Time for my 2c Anyone who has read my posts know I`m a minimalist That means no electronics, no electricity, no head What I have is a galvanized iron bucket with a seat on it.
This means no clogged head, no changing head gasket kits, no leaks. NO ODOR: a few miles off shore and I dump the bucket overboard into the Atlantic ocean. Unfortunately this system wont work in fresh water
n fresh water
Mar 1, 2012
2,182
They are called "wag bags". Put it in the porta potti, use it, seal it up Work fairly well for short term usage , particularly in lakes. Legal to dumpster them when you come back in.
One caution- they DO smell lif you put urine in them, otherwise, not bad
Oct 26, 2008
6,432
It's funny how people don't seem to listen to the poster's implied desires. I think he said he already has a porta-potty. Reading between the lines, I gather that disposal is a task that they don't find particularly appealing. It also seems that capacity of a porta-potti is also an issue based on their anticipated vacation plans. They seem to WANT a regular toilet with holding tank and are asking if it is worthwhile to make it a project (read - get rid of the porta-potti). Now we have a bunch of folks who are regaling them with the charm and utility of emptying buckets of human waste. What a laugh! Install the toilet with a holding tank. If you have access to pump-out facilities, it will make life much more pleasant. (my particular favorites are the posters who suggest that they dispose their waste offshore, when the posters live in LAKE country!) bffatcat, exactly how is agprice supposed to empty his buckets in the Atlantic Ocean?
Oct 2, 2006
1,517
Jboat J24 commack
Well
You got a pumpout or you dont and if there is NO pumpout its carry the porta potti
We love are sealand traveler as it is everything in one simple unit that use very little water
kito
Sep 13, 2012
2,011
He should tell us if he even has access to be pumped out. If not, then his porta pottie or crapping in a bag is his only choice. Or he can just jump in the water and launch a few....which I believe is legal. You just can take a dump in a bucket and throw it overboard.
Jul 1, 2010
990
Catalina 350 Port Huron
OK, where are the composter folks? We have a marine head on our boat, but if we didn't already, I'd put in a C-head or one of the other composters. I considered taking out our marine head this year and swapping to one of these, but I'm going to go with the known entity for now, and just replace the hoses.
Ours has a 10 gal tank, and that's small enough that you don't get too many days between pumpouts when you're cruising. I like the idea of not having to worry about it with one of the composters, but I've never used one, and there are always some compromises whatever system you use. I've used the wag bag setups before, and would again in a pinch, but they aren't pleasant.
Aug 3, 2012
2,542
This has been good. I appreciate the bag and bucket idea, but I don't see ferrying that back to land in my dinghy. The Admiral won't appreciate that, but maybe she can adapt? True, I can't dump. I will be on Ontario and Henderson Bay, which I did not say earlier, but I did say we were lake sailing. We want to incrementally increase the difficulty: Lake - Bay - Inland Sea (Great Lake): Daysailing- Coastal Cruising. Someday back to the Atlantic where I grew up sailing small boats. Correct, Portapotty-ing is not our idea of pleasant. Same as the bucket... I can't dump it, and I ain't keen on ferrying it back to land, where there is no bathroom to empty it. Our boat will be moored 3 hours from home, so I would probably have to carry it all the way home. Or, if I use a bag, maybe I could drop it in a dumpster? There are a couple of pumpouts on the bay, so pumping out a head is an option. I guess I should get the locals fees for a pumpout to factor into the decision.
I can't see installing a macerating type system. A holding tank seems feasible.
Thanks !
Andrew
Aug 22, 2011
1,113
In our case a FULL bag weighs about 1 lb wraps into a small packet can be easily triple bagged with plastic shopping bags for handling and placed in regular trash.
We have 5 quart airtight plastic jugs we picked up cheap and for long trips store several bags in those. End of trip - haul to dumpster or home. Not really hard to handle - just distasteful due to our own preconceived notions. Picking up dog poop and cleaning litter boxes is worse I think.
We haul stuff to the boat and we haul stuff out. No biggie.
Aug 3, 2012
2,542
In our case a FULL bag weighs about 1 lb wraps into a small packet can be easily triple bagged with plastic shopping bags for handling and placed in regular trash. We have 5 quart airtight plastic jugs we picked up cheap and for long trips store several bags in those. End of trip - haul to dumpster or home. Not really hard to handle - just distasteful due to our own preconceived notions. Picking up dog poop and cleaning litter boxes is worse I think. We haul stuff to the boat and we haul stuff out. No biggie.
Gotta admit, you make a good case!
Thanks
Nov 22, 2011
1,296
Ericson 26-2 San Pedro, CA
Peggie Hall knows more about heads than anyone! She recommends a porta-pottie.
Read this: http://forums.hunter.sailboatowners.com/showthread.php?p=1080526&highlight=porta marine
You use it, carry it to a toilet, rinse it, and you are done. About 10 minutes.
Agreed. Peggy is quite correct on this.
At her recommendation I installed an MSD porta potty with a built-in 5.5 gal. tank in my 26 footer. It has considerably more real working capacity than I had with my head with 14 gal. holding tank on my previous Catalina 30. And it's precisely because it uses so little flush water, just as she said. No problems with odor, either, and the thing is utterly reliable: no joker valves to replace, pumps to lube, etc.
I have mine plumbed for overboard discharge through a macerator for when I'm 3 miles offshore. I understand in this case it would be used in a no discharge area. I don't know whether there are any dockside pumpout facilities available (perhaps that was mentioned and I missed it). If so, then an MSD porta potty could be easily set up to be plumbed to a deck pump-out fitting.
Jun 21, 2007
2,118
I came to this same conclusion in 2007 when I was deliberating replacing the entire system in my newly acquired 1980 36' Cherubini Hunter. This even before I read Peggie Hall's lean towards porta-potties (PP's). Granted my need is primarily day sailing for when I have guests. And for the occasional 1-3 day ventures somewhere. My PP can also plump to a MSD pump-out. But with several gallons of holding, really not necessary for my normal need. Much easier just to grab the holding tank portion and bring it to the nearest PP facility ... like my home's EPA approved municipal sewage system. And carrying home is much easier then docking my seriously heavy prop-walk boat into unfamiliar pump-out facilities.
My PP model has a fresh water tank and a battery operated pump to swirl the fresh water into/around the bowl. To use, a quick push of fresh water flusher button to wet the bowl. Just a couple of ounces. The person does what comes naturally. Pull open the flap. A couple of quick pushes on flusher will fresh water rinse the bowl into the holding tank. Then push close the flap. Simple. And guests can do it without much instruction.
The PP seals are good. So never any odor in the boat. One PP modification I made though was to plumb an air vent line to the outside.
Not mentioned anywhere yet is that one can also have on board a (say) 5-10 gallon secondary wide-mouth plastic holding "jug". When the PP tank might get full, pour it into the jug. My daughter has a cat. The plastic container that the cat litter comes in is large and has a very wide screw top opening that seals quite tight. Perfect.
PP pour out can be gross, yes. But over-all, I haven't yet regretted the PP alternative.
