Several current, related threads on boat speed and performance has prompted several forum members to reach out to me and ask my thoughts on boat performance, polars, and if their boat was 'fast'. After responding and a bit of thought, maybe I've come up with a generalized answer. I'd be interested in everyone's thoughts.
First of all, I think it's better to think about a performance in terms of 'quick', and not 'fast'. Overall top speed, or 'fast' is largely a function of hull/LWL length and wind speed, and is not a great performance measure. So we have to look elsewhere.
We also have to factor on size. As mentioned above, a boat's speed potential through the water is a function of length, so performance will be relative to that.
But even if we factor in length, what is a true measure of performance? We know its not a beam reach in 12 knots, because every boat will feel 'fast' them.
When I was on the Ski Team, I had a coach who had a favorite saying... he said; 'Making turns where you want to is easy. Making turns where you have to is hard.'
Very true, and there is a corollary in sailing. Sailing where you want to is easy. Sailing where you have to is hard.
That's why I like to look to PHRF racing performance numbers as an indication of how 'quick' a boat is. These handicap numbers measure a boat's capability to sail where it does not want to go; ie, straight upwind and downwind in all ranges of wind speed. The difference between any two boat's numbers are the number of seconds one will sail a mile faster on the racecourse. So the smaller the number is, the 'quicker' the boat is. By factoring boats from all over the USA, US Sailing uses a large base of boats to get a accurate picture of every boat. It's not perfect, but its very good.
But back to our question... what IS quick? And remember we have to factor in length. To start to create an answer, I built up a table of quick-boat PHRF numbers based on length. To try and get a sense of what a quick 'control' boat would be, I used all the J/boats and the First series in the range of 21 to 35 feet, and averaged them where possible. The results are shown below.
Its clear that each range has its very fast boats, and some slower and more 'cruisy'. But the range follows the slope of the linear line which plots each foot knocking 8.3 seconds off a boat's time/mile. The only big exception is at 28 feet, where both ranges have a slower cruiser model.
So, I put forward that if your boat's PHRF number is in the area of the CURVE or AVERAGE number based on length, its a quick boat. Lower and you are very quick. Higher and you are slower, and more cruisy.
Now, even if you do not race, there are real world applications. In general, a boat that has a lower PHRF number for its size will sail better. It will turn faster, accelerate faster, go to weather better, and do better in light airs.
You can find your average PHRF number for your boat here:
http://www.ussailing.org/wp-content...Current Base Handicap Class Hi Lo Average.pdf
This of course is for non-planing keelboats with in-cabin accommodations. And one size does not fit all.
Thoughts?
Thoughts?
