9-30-14
Problem Fixed. Thanks to all for your assistance. The spade connector was so loose it was just "hovering" in position. I finally got eyes and fingers on it thanks to Jesse and fixed it.
Thanks again.
Neal
Hello all,
We purchased our 2003 Catalina 310 in Grand Rivers, KY and headed out for a 340 mile cruise up the Tennessee River to our home in Guntersville, AL. We made the trip in 7 days. Most of the trip was great with the boat and engine performing smoothly. Two issues popped up I could use advice on.
1. Low oil pressure alarm intermittently chirping under way. It only sounded off fully when turning key to start engine. It was just a light inconsistent chirp. I checked the oil level several times a day and never noticed it low. Also kept a sharp eye on temp gauge and it stayed consistent the entire trip. My thought is the sensor is going bad. What do you think and is this a simple fix?
2. With 5 miles to go before home, the engine had several moments of rough running and losing rpms. It ran smooth as silk for 335 miles and then just 5 miles from home I was concerned we would not make it. It never quit running, and would smooth back out and run ok for a while before stuttering again.
We started the trip with new filters (fuel and oil), and kept the fuel tank topped off. Only once did we approach 1/2 full mark.
The engine is a Universal 25, common to catalina 310 as I understand it.
Any thoughts or comments would be appreciated.
Neal
Thanks again.
Neal
Hello all,
Neal
