thinwater, when using a climbing rope, is the rope thread across the sheave and back down like a halyard? I'm assuming it isn't safe to simply tie-off the end of the climbing rope to the end of the halyard and hauling it to the top. So do you typically exchange the halyard for a climbing rope the same way that you would for exchanging halyards? It seems like a fair amount of work for the task, but obviously necessary, unless I'm missing something.
When you look at racing rigs, they seem to have crew go up the mast for various reasons on the water. Are they rigged with a dedicated climbing rope or are they using a halyard. If you are actually just hauling a climbing rope to the top with a halyard, how is that made safe?!?!
I did not mean that one must use a climbing rope for safety sake. I meant that...
* I have seen folks try to fit jammers and belay devises onto ropes that are not within the engineered size range.
* I've seen people with slack in the rig that would not be safe if they fell; climbing ropes stretch, but halyards do not, resulting in very high impact forces.
* Though I did not mention it, it is also not safe to use rope graps on HMPE (Amsteel etc) ropes; they do not have the same friction characterisitcs as nylon and polyester.
None of this applies if you are being hoisted up by the halyard winch. It only applies if self-belay is invovled.
However, it is common practice amoung riggers to bring their own climbing rope. They simply tie this to the existing main halyard (assuming the existing halyard is 5000# rated and in good condition--if not, it should be replaced first). The reasons are...
* To save wear on the halyard. The rope grabs spike the rope and the existing halyard may be very high-tech. It saves wear on the customer's gear.
* To insure the rope is the correct size and fits their gear. Why wonder each time you aproach a job? Take your own tools. Part of my work involves refinery inspection, and though the plants have their own gear, I bring my gear for my use. I know how it works and its condition.
I do this myself because my halyards are 1/2", whereas most climbing gear is 3/8-7/16". Though my grabs will fit on 1/2" line, the 10.5mm line gives a better fit and runs smoother. It is nylon and stretches, but that is OK for a safety line. If you use rope grabs, a non-stretch primary of just the right size is needed.
Most sailors would benifit from having a separate climbing line that is is just the right size and dedicated to this single purpose. It will fit the gear correctly and take the wear. This is vital if the halyard is other than polyester double braid, in my opinion. The Top Climber manual probably says this.
