O day 222 Mast destroyed
Jul 15, 2013
4
Oday 222 Otsego Lake
The mast on my o day 222 came crashing down yesterday while racing in 15mph winds. It bent in half just above the spreader and then sheared off at the tabernacle. Totally destroyed. I think the forestay pulled out. Anyone know where I can begin to look for a replacement mast? I think it's a 1988 and spar rigged.
Thanks!
Nov 8, 2010
11,386
Bummer!
That sounds like typical spreader failure, or the mast section buckling at the spreader base. The mast is highly loaded there. By chance is it a z-spars z-190 mast? They were susceptible to that.
Jul 15, 2013
4
It is z spar, not sure what you mean by z190. Yeah broke at the spreader. Any advice? I know of d n r marine. Thanks!
Nov 9, 2012
2,500
Oday 192 Lake Nockamixon
Yep. Z-spars masts on the 192 and 222 have a reputation for being a bit weak. The boats often came with a Dwyer mast, which is more robust.
I would call Rudy at D&R, and see if he knows anyplace up around him in New England (where there were many O'days) that might have a used mast.
Worst case scenario, you could buy a new mast. Rudy sells full masts. I don't know if they are Dwyer (Damco) or Z-spars. I suspect they would be Dwyer.
You could also probably get from Dwyer. Z-spars parts are also available from www.rig-rite.com, but I don't know if they have whole mast sections. I know Rig Rite has Z-spars mast foot castings, etc.
This is really sucky for you, I'm sorry. Reminds me that I don't know how old my standing rigging is, and I should just replace it all to be safe, even though the visual inspection has been ok.
May 17, 2013
13
Oday, Northstar 222, Hughes 1000 Elbow SK
O'Day 222 broken mast
Thanks!
The mast on my O'Day 222 broke at the same place as your. I found a welder who repaired it at a fraction of the cost of replacement. I have been sailing 2 Summers with it, without a glitch. I feel it is stronger now than before the weld!
Good luck with yours!
JM
