IPad mini and GPS
shyamh
May 8, 2014
24
Beneteau 375 Seattle
Good morning all,
What external GPS receivers would you recommend for use with iPad navigation apps?
Would you recommend it over a device with cellular and in-built GPS?
I have a 30' sailboat with no electronics on board and am considering an iPad setup with my Charts&Tides app (and any future navigation apps I might buy).
Thanks in advance
shyam
Ward H
Nov 7, 2011
3,843
The Amazon product info for the Bad Elf GPS Puck shows a photo of it locking into 8 of 13 sats. In theory that should be more accurate than the iPad which, from my reading only picks up 3 sats.
My old Garmin MapGPS 196C will acquire up to 12 satellites. When I have the two side by side the dedicated Garmin unit seems to update quicker than the iPad by a few seconds but accuracy seems about the same.
I would be worried about an external puck, powered by the iPad draining the battery much faster.
I wouldn't buy an iPad without cellular. You don't have to add the plan if you don't want to but if you change your mind later and got WiFi only, your stuck. The savings of going WiFi only will be eaten up by the GPS puck.
But then, that is just me. I only day sail in a bay where I don't really need any GPS to find my way around. If I was going to navigate some tricky waters and needed the best accuracy and fastest update, I think I would go with a dedicated GPS first and iPad with GPS Puck second.
If you haven't done so, try the Navionics app. Maps are be bit more but it is a sweet app.
Jan 25, 2011
2,439
S2 11.0A Anacortes, WA
I went down this path last spring. Ended up buying the biggest and baddest iPad Aire available. Have not activated cell but I'm glad I went this route as I use the iPad as a planning tool and quick reference for tides etc. I also use it for other purposes such as photography. I would spend the "Elf" money on the iPad.
shyamh
May 8, 2014
24
Thanks for the quick replays. I also read the previous thread on iPad use
Good point on battery drain with something that docks. An external Bluetooth would have it's own power source which I would guess is better in that sense.
How about weather resistance? I'm in Seattle where, you know, there is a lot of moisture :)
This is, as you can imagine, a recurring question - iPads for navigation, do they have built in GPS?, are they waterproof (nope - but they do make cases for them).
In many cases, even for boating Google can be your friend, since there has been soooo much written about these devices, and their pros and cons.
Also check out these resources:
www.activecaptain.com has recently written a series of articles on onboard navigation and connectivity
www.panbo.com also has lots of electronics information
You could also do a search on this forum (upper right blue tab) for iPad or iPad navigation and read for weeks.
Good luck.
shyamh
May 8, 2014
24
Hi Stu, I'm using the forums via the iPhone app and the search features are a bit obscure here.. :( I'll try the web version
I was asking about the weather resistance of external GPS devices. For instance, the DUAL XGPS devices--can it be mounted on deck and withstand splashing salt water or rain?
Overall looks like there is strong recommendations on going with a cellular cable iPad which is an all in one solution.
I'm curious if there is any scenario where separate units make more sense
Thx
Ward H
Nov 7, 2011
3,843
Mark mentions other uses for the iPad. Some boat related things I do are:
All boat related manuals are in PDF form and on my iPad.
I keep my sailing log on my iPad.
I have multiple weather/wind related apps I check before sailing.
Bad weather alerts appear on my iPad.
Forum suggestions/instructions, (like RichH's how to raise a Dacron sail) are copied and pasted into notes on my iPad.
All of this is synced to my phone which is also always on the boat, in a waterproof floatable bag, as a back up and all that stuff is also synced to my home laptop.
shyamh,
The only waterproof GPS pucks I saw were connected via USB, which the iPad does not have.
Feb 17, 2006
5,274
May I be one to suggest an Android Tablet vice an Apple device. Difference, to me, is night and day. More control over the Android than the Apple. I am not 100% sure but I do not think the Apple accesses GLONASS. Again, I am not sure. But I am 100% sure Android Tablets do access GLONASS.
As for the GPS antenna, it can reside in the cabin. There is a little loss of signal but not enough to desegregate performance. My Garmin 72 is in the cabin connected to the radio.
Waterproofing is as simple as a gallon ziplock bag. That is what I keep my Samsung in while I am on the water.
Good luck with your research and purchase.
Nov 9, 2012
2,500
Oday 192 Lake Nockamixon
If you already have an iPad with Wi-fi only, then consider the Dual Bluetooth receiver http://www.amazon.com/Dual-Electronics-XGPS150A-Universal-Bluetooth/dp/B006M49G80/
If you do not already have an iPad, then buy an iPad with Wi-fi and Cellular (your choice of carrier - you DO NOT have to sign up for cellular service, but you do have to pick if you want AT&T, Verizon, etc.)
The cellular chips have the GPS built in. The Wi-fi only DO NOT have GPS built in. iPad Air/iPad Mini does include GLONASS as well as Assisted GPS http://www.apple.com/ipad-air/specs/
Personally, I do not believe in zip lock baggies for protecting electronic equipment. From my kayaking, I have learned that zip lock baggies are really good at keeping water IN, not out. I would select a Life Proof case for an iPad http://www.lifeproof.com/en/ipad-air/?path=TopNav They also make nice mounting cradles you could adapt to your particular boat: http://www.lifeproof.com/en/ipad-air/accessories/
Nov 18, 2010
2,441
Catalina 310 Hingham, MA
iPad 3 and up uses GLONASS on the internal GPS.
Sep 16, 2013
4
Morgan Rolf Peterson Port Superior WI
Ive used ipad (love it), iphone (too small, but works), (both with iSailor) and Samsung Note 8 (Navionics), all with cellular/gps. Downside to ALL of them is seeing the screen, both in sunlight, and with dark glasses. Get the ipad and waterproof case and a mount for the cockpit. Plan on it running out of juice in less than a long day. Or keep it plugged in below, without the case.
Bob S
Sep 27, 2007
1,815
Beneteau 393 New Bedford, MA
What advantage does GLONASS bring? My Raymarine C70/Raystar 125 and my backup Garmin handheld are using WAAS GPS. I don't believe they link to GLONASS. Just curious. I use my Ipad with NavionicsHD for planning but rely on my mounted and handheld chartplotters on the water (I still have paper charts for my sailing area).
My iPad is WiFi only and was thinking of making my phone a hot spot but then I stumbled upon the Dual Electronics XGPS150A external WAAS GPS or their SkyPro XGPS160 GPS Receiver which boasts Simultaneous GPS and GLONASS reception, Up to 10 position samples per second, Bluetooth wireless connectivity to up to 5 devices. It appears to be designed for aviation. $60 more?
shyamh
May 8, 2014
24
How about foul weather scenarios? Is the iPad comparable to other external units in being able to still get a lock on GPS?
Feb 20, 2011
8,062
GLONASS capability provides redundancy. A back-up system, if you will.
Nov 18, 2010
2,441
I have been using our iPad for navigation for 2 years now and have not had any issue with foul weather interfering with it. I also follow blogs for many younger cruisers who use the iPad for navigation and they have not reported any issues either. I don't think this is anything to be concerned about.
Jesse
Feb 17, 2006
5,274
It also provides for better accracy (IMHO). The more signals to triangulate the more precise you location. GLONASS, I believe, had its positioning error reduce to a much smaller area than US GPS birds. While on the water, I have had up to 21 locked satellite with half being US and the other half GLONASS.
Feb 20, 2011
8,062
A quick search reveals that you're right. A dual antenna system provides greater accuracy.
I wonder how each system's accuracy as a stand-alone compares?
Bob S
Sep 27, 2007
1,815
I thought the WAAS was accurate to 3 meters. I wish I was that accurate with paper charts ;). Redundancy is a good thing.
Feb 17, 2006
5,274
As for accuracy I am not sure. As for error, I can say my Garmin never gets me within a boat length (27 feet) of my reported position. But when I use both USGPS and GLONASS my reported position is half a boat length, or about 13 feet. That, when the boat is docked, puts me in the correct slip on a NOAA chart. Now I am impressed. :)
