Teak slats in cockpit of Beneteau 311
Jul 1, 2014
15
Beneteau 311 Toronto
I recently bought a 2000 Beneteau 311. The teak slatted pieces on the swim platform and in some parts of the cockpit are lifting.
They seem to be one piece that fits into a fibreglass recess.
I'm not sure how to repair them - whether to remove them entirely and then reseat or glue the edges down? What glue to use?
Any help appreciated.
Adam
Jul 1, 2014
15
Adam
Thanks for the help!
Ron M
Mar 21, 2010
67
Beneteau 331 Rock Hall, MD
Reseating teak slats
I used a small (1/2" wide) spatula with a very bendable blade to clean underneath the slats without trying to remove them. Worked reasonably well.
I have some photos if you are interested.
Ron M
Mar 21, 2010
67
Luckily my problem was in the removable seat, so I could bring it home. That made it easy to use clamps to hold the teak in position while the adhesive dried. Just noticed that I have another problem which will need to be repaired in position. Applying pressure will not be as easy.
Also, removing the old adhesive and water with a thin rag helped. You could see when the location was finally dry.
Supplies: Boat Life Silicone Rubber caulking (black)
Sikaflex 291LOT adhesive (black)
#6 x 1/2" stainless screws
Good luck......
15
Good luck......
Hi Ron,
Thanks the photos. They're very helpful. Are the screws important? Can you recall how long they are? Thanks again.
Jul 1, 2014
15
Hi Ron,
Hi Ron,
Another thought. We looked at a 311 in Jabins Boat Yard in Annapolis where some slats were being repaired. After gluing they had put a heavy starting battery over the repair to press down for a good grip. It didn't occur to me until later why the battery was there. A mushroom-shaped lunch hook might work as well.
Adam
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
Hi Ron,
Adam
I did a similar repair on the sugar scoop deck, but took the teak completely off, cleaned surfaces and reattached with heavy duty exterior construction adhesive. Instead of a battery, I used a 40 pound bag of water softener salt for weight. It followed the deck contour better than a flat bottomed battery.
Jul 1, 2014
15
Another good idea. Thanks.
Ron M
Mar 21, 2010
67
I used the screws because Beneteau suggested them and wasn't convinced that adhesive only would do the trick. I believe they were #6 x 1/2" stainless steel.
Oct 28, 2021
55
Beneteau 323 Wiarton
I need to do this same type of work on our Beneteau 323 transom teak slats - water is getting underneath now. In this forum, most answers to these questions involve posting a link to a Beneteau USA FAQ page describing how to do the repair. Problem is that these links are no longer live. Any advice?
May 1, 2011
5,556
Pearson 37 Lusby MD
This is a 10-yr old thread and most of the posters haven't been seen in some time. Recommend you start a new thread.
Likes: nitrogenase
The images in this thread show that the teak seat was a solid board that was grooved to show a slatted relief.
What does your project look like? The above design would tend to “bend up” as the wood dries and gets wet over time. Left alone it would eventually crack and split. The recommendation of “Screws” is a temporary (few years) fix. It creates an opportunity for water to find its way under the teak and into the deck core.
The use of Butyl adhesive caulk like Dow 791 or their Glass/Metal sealant might work. The problem is the wood is oily. It will tend to curl (thus the recommendation of Beneteau to use screws). If you want to make the project permanent (stick down not to be removed) then try 3M, 5200. The black filling to create the slat look is likely Dow 791 in black.
TheZ3
Jun 3, 2024
9
Beneteau 323 Old Hickory Lake
I purchased my 323 in spring 2024. The teak is further down the list of projects. Currently the caulk joints are protruding higher than the teak and the ends of brads are beginning to expose in the teak. My "plan" is to remove the teak and replace with Sea-Deck. Not as classy just a lot easier to maintain and it doesn't get as hot as the teak in direct sun.
The refinished teak in Ron M's photos looks amazing and almost has me second guessing my initial thoughts. Anyone remove/replace the teak in the cockpit and stern with suggestions or advice?
Aug 14, 2026
3
Hunter 33 san diego
Those cockpit slats are a pain once the fasteners start working. Some folks sister in new teak, others go to a one-piece synthetic teak panel so the cockpit sole is one surface again. If you are weighing replace-in-kind vs overlay, that second option is usually less carpentry and less seasonal upkeep.
Apr 10, 2010
153
Catalina 310 166 Dartmouth, Nova Scotia
For weight on any gluing or epoxy situation I usually purchase a bag of playground sand and place that on the area requiring it. It's a good weight , conforms to the shape of the repair, is easy to handle and can be reused or disposed of in the winter for traction in snow or ice.Or in the summer at the nearest playground that has a sandbox. Or kept for the next project.
