Just a quick note to see if anyone else has worked out a solution to this particular problem. I decided to install an engine hour meter on our 376. There was already a fuel guage mounted below the left side of the engine control panel, so I thought I'd balance it by putting the hour meter on the right side. I had to remove the panel to access the area. When I pulled it out, I found out that there was so little clearance between the panel and the steering cables that the cables were chafing against the engine panel wiring harness. I'm curious if anyone has had a problem with the cables sawing through the wiring harness insulation. I'd also appreciate any tips on how to keep the two separated if anyone else has fixed this issue.
