I recently purchased a '87 C30 and have been figuring out a lot of my own questions, but can't figure this one yet:
The two teak trim boards that go from the companionway hatch forward (on the deck) have drain ports near the companionway (which are clear), but nothing at the forward end.
There is usually standing water in the track, and the forward sections of each are notably moist. There is no similar drain in the forward sections (?).
Has anyone had the same problem and, if so, any suggestions? Drilling weep holes in the teak seems like the simple solution but I'm a bit hesitant to start blindly drilling in my 'new' boat!
Thanks for any input.
6/08: I've added two pictures: one at the companionway/hatch, showing the drain port under the teak that allows any water in the track to go out onto the deck. The other is the forward end of the hatch and teak boards, showing the water seeping out. This is where I'd think there should be a way for the water to drain out onto the deck vs soaking into the wood? I don't see any holes that are plugged up. Hopefully this makes helps w/my explanation of the problem. Thanks.
