kittiwake owners
Dec 7, 2012
515
Kittiwake 23, Irwin 43 .. Indianapolis / indianatown, fl
hello all
I am looking for other kittiwake owners on here... I am a new owner of a kittiwake sailboat... I am looking to talk to other kittiwake owners on this site... I would like to seek their advice on modifications, changes, and improvements on the boats...
sincerely
Jess
Jun 5, 2014
9
Kittiwake 23 23 Texas City
hello all
sincerely
Jess
I just picked up a kittiwake 23 Hull # 205, need as much information as I can get on her. Just pulled out and having a bottom job done. Need to replace all the topeside wood, especially hatches, help!
Dec 7, 2012
515
hello
welcome to the family
I have hull no#214.... there is something special about these Kittiwake boats.... I am doing some repairs to the keel right now... when I bought mine it had set on the trailer for 10 years and not used.... I will be repainting the bottom, the deck, and the inside of the cabin... I am putting all new ropes on it... I am adding hardware and winches.... I plan to set it up for solo sailing... I am putting a block plate under the mast step... I also set up the mast for the main halyard and jib halyard to run internally.... the one big shieve inside the mast at the top, I replaced with 2 shieves ... and I put 2 blocks on the masthead to handle the topping lift and the spinnaker halyard... I am also replacing the single axle trailer with a newer tandem axle trailer this week....
I see you bought Fred Hastings boat.... there is a Kittiwake registry site... it has some information, but the site has not been updated in years... you can also go to yahoo groups and talk to other kittiwake owners... I believe someone said there is a group of kittiwake owners on facebook too... there are a couple of kittiwake owners on this site too...
if you have any question or need help, just ask... I will do all I can to help you...
sincerely
Jess
Jun 5, 2014
9
Can you take a picture of where and how you have located the bilge pump, mine has non, so purchased a
Hopefully will be suitable. In addition my outboard mount is toast, can you also show me what your looks like.
Thanks for the welcome
Trevor
hello
sincerely
Jess
Dec 7, 2012
515
hello
nice bilge pump... you got a good one... you need one that is automatic, not one that needs a separate float switch...
my outboard motor fit under the hatch at the rear of the cockpit... I have a 1965 Johnson seahorse 4 hp outboard motor... it has the long shaft for the sailboat...
if your motor well is missing or damaged, I would suggest you rebuild it, and reinforce it with a wood brace.... the brace can be used for the motor mount too....
for information on the boat, go to 'sailboatdata.com'
I will try to get some pictures for you....
sincerely
Jess
