1990 Hunter 30 2gm20f propeller question
Oct 24, 2009
7
Hunter Hunter30 Powell River
My hunter has a 2 blade prop, my question is... Is this the stock propeller from hunter?
I am wondering as it seems that the boat only does 5.3 k at 2700 rpm. and it seems most H30s will do in the 6 k area.
The boat is fresh paint with a clean propeller.
thanks
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
thanks
what is your wide open throttle RPMS..can you hit 35 to 3600 rpms....if not you may be propped to aggressive.....
May 24, 2004
7,235
CC 30 South Florida
Before doing anything you need to ascertain that the tachometer reading is accurate and that your speed reading is indicative of pure boat speed "over the water". (no GPS). Once you can say for sure that there is a problem with low RPM then you can start diagnosing the engine and drive train. Throtling up the engine in neutral and seeing if the RPM remain low or go to normal can provide a starting point of what to check and what to eliminate. The diagnostic process is a little more involved than what I could cover here. To answer your question Hunter basically delivers its boats with two blade props but not all two blades are the same as they can vary in diameter and pitch to match different engines and boats. Is it possible that a PO improperly replaced the prop? Yes it is possible but not likely. Engine running condition and whether it is smoking or not can provide a wealth of clues. The most basic thing that you could do is verify that the throttle linkage has full travel.
Oct 24, 2009
7
The engine will hit 3500 in neutral, I have not tried in gear but don't think so. Is there any way the prop could be slipping on the shaft and reducing my speed.
Where can I find out what prop should be on a 1990 Hunter (factory installed)
I am thinking I will lift the boat and put on a new prop, but am curious about a slippage problem with existing prop.
Thanks.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
There are prop calculation formulas on the net or you can contact a prop company like Michigan wheel/propeller and have them figure it for you
Nov 17, 2011
69
Hunter 306 Chester Basin, Nova Scotia
I switch the factory 2 blade prop for a 3 bladed max prop for my 30' hunter.... Huge improvement. 2700 rpm is usually around 6kts, can push it close to 7 if I have to max it out. Of course wind, waves, etc all play factors.
Oct 24, 2009
7
I am thinking my prop is slipping on the shaft a bit as I tangled it up in a ton of weed last week. I want to buy a new prop but would like to just keep it the same.
Any idea on what the exact hunter factory prop is in diameter and pitch and LH or RH.
Thanks
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
Thanks
i dont think your prop is slipping on the shaft if you can get 5.5 knots at 2700 rpms
as far as size my 30 ft boat takes a 15d....11p...Rh and i have a 2gm20f just like you do my boat weight is 9800 lbs and has a 5 foot draft
Oct 24, 2009
7
Thanks that's what I needed to hear. No slippage is good, so no lift required.
This is just my first encounter with a jammed prop. I dove down in cold water to cut the weed off.. and don't want to go in again...
Oct 24, 2009
7
Just in case anybody else is wonder the factory prop for the 1980 Hunter 30 is
15"x12"xRH and is mounted on the shaft with a keyway.
