I've read in the manual that draining the fuel tank is regular maintenance. Is this necessary if you use a fuel strainer?
If so, where is the valve, how do you access it, what size hose do I need?
Could someone walk me through the process on my 1993 Hunter 27 with a Yanmar diesel 1GM10?
I assume I should run the motor until I "think" it's near empty (12 gal) before diving into this.
If it wasn't for you guys my learning curve would be flat!
Thank you.
Thank you.
