34/35 shower sump
Sep 23, 2009
1,478
Was working on my very new to me '84 O'Day and couldn't find the shower sumo so I guess there isn't one. I am hoping to keep the bildge clean and dry so would like to add one.
Anyone ever done this or have any idea where to add one? How to run the plumbing?
Thanks for any help.
Larry
Also found the original manual today if anyone needs info from it.
Jan 27, 2008
3,092
ODay 35 Beaufort, NC
Correct no sump it drains into the bilge. Keeping your bilge dry will be tough. Water can get in from the stuffing box and openings in the mast plus condensation. I have no idea how to add a sump the bilge is the only place lower than the floor. So to drain the shower the sump would have to be in the bilge.
Aug 17, 2010
374
Oday 35 Barrington / Warwick RI
The sump on my.' '87 O'day 35 is the shower floor. There is a drain which connects to a pump under the port setee, this then pumps the shower drain overboard.
Jan 27, 2008
3,092
Very good idea to run the drain hose from the shower directly to a pump, hadn't thought of that. A "Y" valve on the toilet raw water through hull would allow that to be used for the discharge. I like it. Do you have a wooden access panel in the floor of the shower like mine? I assume that is sealed somehow to not leak into the bilge?
Sep 23, 2009
1,478
In the head there is a small teak and holly panel under which is only a few inches of space which is filled with a hodge-podge of wires. The drain is close to the centerline and must drain in to the bilge forward of the mast. There should be a center panel in the floor between the door to the head and the closet but a PO has covered the area with teak and holly ply all the way back to the table so some cutting may be in the future if there is room for a sump forward of the mast.? Where should the discharge go?
Jan 27, 2008
3,092
I'm thinking just get a hose, connect it to the drain in the shower. Connect the other end to a typical water pump, like a washdown pump or similar. So the water stays in the shower pan until you turn on the pump and pump it dry. The pump can go under the port settee adjacent to the head bulkhead where your on demand water pump is located. Then add a y valve to the head intake so in one direction the head intake works, in the other direction you pump the shower overboard using the same thru hull. I think I might be talking myself into this project. :>)
Aug 17, 2010
374
There is an access panel, covered by a piece of Teak & Holly, on the floor of my O' 35. The "seal" is a bead of silicone that the panel sits on top of.
I would NOT use a Y valve on the toilet intake, unless you want to run hair through your toilet, which could lead to other issues. There are two small discharge through hulls, both above the waterline, under the sink. One of them is for the sink, the other is for the shower.
Aug 17, 2010
374
If you pull up the panel you describe, you will find the FG pan that the O'34 has.(BTW- the "closet" is referred to as a "hanging locker.") There is no access here.
The only access under the floor pan is in the head compartment, under that panel (unless you take a saw to the pan - I would advise against that).
You can put a 1-1/8" ID bilge hose on the stub of the drain, and attach it with a hose clamp.
This pump will frequently run dry, and will have to contend with soap, and hair. You should use a shower drain pump, and not a washdown pump.
Jan 27, 2008
3,092
How about running the drain hose into a "y" valve that then goes to the macerator pump. Then you don't need another pump, the macerator can be used for both purposes?
Sep 23, 2009
1,478
Thanks for all the great ideas!
I have seen other 34s with both one or two thru hulls above the waterline. Mine just has one for the sink. Might add a pump with a high loop and vent to a thru hull under the sink or a sump in the bildge in the fall. (mean while still working on engine and head intake thru hulls.)
