Continuous furling line splice... now what?
464
Catalina 30 MKIII Varuna Boat Club
I recently completed an end to end splice on a new 1/2" continuous furling line for my Hood furler on my Cat 30.......and the splice won't fit through the lead blocks that are mounted on my stanchions.
I can't find blocks that would accommodate the bigger diameter spliced area and also thought about using fairleads.......with no success.
Any ideas?????
Jun 1, 2004
8,347
Any ideas?????
Well, 1/2" seems pretty large for a 30 foot boat. Is that what Hood recommends? I think your options are pretty clear.... go with 3/8" line... or 5/16" higher quality.
Oct 10, 2009
1,117
Beneteau 393 Muskegon
These furlers do require a pretty fat line, so that the teeth in the drum have more surface area to grab onto. I have an 810, which I have seen on several Cat 30s, and for that model Hood calls for a 7/16 line, as I recall. So, maybe a slightly smaller line, but an end for end splice should not have a bulge; a redo seems in order.
Oct 2, 2006
1,517
Jboat J24 commack
The key word in this is constant diameter endless splice
I am mediocre at it having only taken it on when i could not get it done i found with massive stretching it should skinny down as it is a weak splice dependent on the outer jacket
Nov 23, 2011
2,023
MacGregor 26D London Ontario Canada
Re: Continuous Furling Line splice....Now What?
That YouTube link is great!
Thanks for posting it.
464
The worn line that I replaced is a 1/2". Truthfully, I'm trying not to have to re-splice and am looking for an easier way out......
464
The bulge in my splice is maybe....a hair bigger than the one shown in your photo. Does your line hang up at all?
Oct 10, 2009
1,117
Did you try rolling it out and milking it some more? That may help to orient some of the strands and smooth things out.
Nov 6, 2006
10,253
I agree.. wet it with a heavy dish soap/water solution then roll it and milk it.. Roll it by standing full weight on it and sliding your shoes/feet over it while it rolls on deck. Milk it from mid splice outwards toward the ends of the splice.
