The mounting points for the split backstay on my boat are so close to the aft horn cleats that the turnbuckles actually rub on the cleats. This not only makes it difficult to adjust the turnbuckle, but also makes it very awkward to put a line on the cleat. There's not really a good alternate location for the cleats, so I'm thinking about relocating the mounting point for the split backstays to chainplates thru bolted through the transom. Anyone see any issues with this? The transom seems to be plenty strong and there is good access. I would mount the chainplates well outboard close to where the transom meets the side of the hull, for added strength. I'm planning to use Schaefer 84-88 SST chain plates. These are rated for 3/16" wire (the backstay is 3/16") and have four mounting holes for 3/8" thru bolts. I would think this would be plenty strong, in fact stronger than the current mounting points which are U-bolts, which I don't really like.
The photo shows the cleat and the u-bolt, with the backstay removed. The cleat is actually worn some from being rubbed by the turnbuckle.
Any thoughts are appreciated!
Gary
Gary
