Autopilot replacement
Mar 25, 2014
12
Hunter 31 Yorktown VA
We're purchasing an '85 H31 that is in need of an autopilot replacement. We're new sailboat owners so any advice is greatly appreciated. Looking for a good quality system at a reasonable cost that's not overly complicated to install ourselves. Ran across a Ray Marine evolution and CPT wheel pilot. Any advice? Thanks...
May 1, 2011
4,868
Pearson 37 Lusby MD
For what it's worth, I have a Raymarine XP-5 that was used for a couple of seasons before I installed a new linear drive. I also have a spare wheel drive that was used for half a season before the XP-5 was installed. The only thing you need is the cable that runs from the course computer to the control head.
Jun 4, 2004
1,087
Mainship Piliot 34 Punta Gorda
Make sure whatever you buy it is compatible with your current or planning to buy MFD.
Oct 27, 2011
154
Hunter 1980 Hunter 30 San Diego, Mission Bay
Just installed a Raymarine Evolution Autopilot with P70 display on my H30. Absolutely love it. Install was completely straightforward (as long as you have some basic DIY skills). No calibration is required; the system "learns" your boat's characteristics and optimizes its steering logic as you sail. (Only issue I had was that the instructions that came with my unit had an outdated calibration procedure that didn't work. Had to call factory to clear this up, but tech was quick to respond and knew the issue exactly.)
So, totally pleased.
Mar 25, 2014
12
Just installed a Raymarine Evolution Autopilot with P70 display on my H30. Absolutely love it. Install was completely straightforward (as long as you have some basic DIY skills). No calibration is required; the system "learns" your boat's characteristics and optimizes its steering logic as you sail. (Only issue I had was that the instructions that came with my unit had an outdated calibration procedure that didn't work. Had to call factory to clear this up, but tech was quick to respond and knew the issue exactly.) So, totally pleased.
Great --thanks, that helps.
Aug 16, 2009
1,000
Hunter 1986 H31 California Yacht Marina, Chula Vista, CA
Kappy, are you looking to sell the XP5 system? I currently have an old but function Simrad WP10 but one never knows how long that baby will hang on. If you are considering selling, send me a pm and we can discuss it.
Mar 20, 2011
623
Hunter 31_83-87 New Orleans
Plan on installing a.ray marine ev100 on my H31in a few weeks. Can let you know then with more info. Did my research and it appears to be a good unit
Mar 20, 2011
623
Yes. P70 head is for wheeled sailboats in our weight
EV-100 Wheel Evolution Autopilot
Features:
A complete autopilot-in-a-box
Evolution Ai for superior performance
No calibration required
Quick and easy installation
Fits most types of sailboat wheels
Simple, robust clutch engagement
For boats up to 16,500 lbs (7,500 kg)
For 12V DC power systems
Includes p70 Autopilot Controller
Includes:
EV-1 Sensor Core
p70 Autopilot Control Head
ACU-100 Actuator Control Unit
Wheel Drive
Evolution Cabling Kit
EV Unit O-Ring Pack (set of 2)
Wall Mounting Bracket
Oct 24, 2015
34
Hunter 356 Brightlingsea
Hi Guys/Girls,
I have just purchased a 2003 Hunter Legend 356 to which I wish to fit an autopilot. The Raymarine new generation looks good, but I don't want a wheel drive, but a linear drive.
Can anyone help with suggestions of type/model and installation photos/experience please?
Regards,
Neil
Jul 27, 2013
298
Hunter 37.5 1065 Rock Hall, MD
I use a CPT wheel pilot. My Legend 37.5 did not have any auto helm. I wanted a strong, simple wheel pilot. I didn't want a complicated hook up, etc. I also don't have a hard wired chat plotter. I use an IPAD with Isailor. The CPT is a 1 horse power motor, and hold the helm steady in 25 knots of wind easy. The customer service is stellar from Jeff at CPT.
Here is one vid sailing back from Baltimore using the CPT:
Ben
Sep 23, 2009
1,475
I am curious where everyone is installing the ev-1 sensor. It should be near the centerline and three feet from metal mass. Not an easy task on many boats. I put mine in galley center locker which requires a lot of extra cable. However I have seen two other installs in the engine compartment. One aft of the fuel tank and one between the fuel tank and engine.
Sep 23, 2009
1,475
Thanks for the great pic Paul. How far is you ev-1 from engine and batteries? Any issues from that? I tried using a handheld compass but never really found a perfect area.
paulj
Mar 16, 2007
1,361
Catalina 310 Anacortes,Wa
4 feet from engine, 2 feet from water heater and 16 inches from ss rudder shaft.
I'm showing you how I installed my auto pilot, if you want to know how to install ask Maine Sail or Stu from c34 web
