I went out sailing on Sunday and I had an issue sailing that I still do not completely understand and thought that someone with more experience might be able to help me understand my sail setup or understand what I was doing incorrectly.
Scenario is as follows:
1. Wind was from SSE.
2. I was attempting to sail due E (on a tack trying to get to the dock which was SSE).
3. Because we were attempting to sail close to the wind, I pulled the main in somewhat to the center of the boat (relatively tight) and put the genoa in relatively tight.
4. The nose of the boat would swing to the N - even with the tiller completely over.
After coming around twice as a result of this, I let out the genoa in an attempt to drop some wind on the nose and keep the nose of the boat from coming around to the N.
Once I let the sail out, the boat would head in generally an E direction - although shading to the N. As we sailed, I tightened the genoa again and tried to get closer to the wind, and the same thing happened - nose started pushing hard toward the N even with tiller all the way over. I let out the genoa and then the tiller started to respond.
We were not heeling much at the time, so it wasn't because the rudder wasn't grabbing enough water. Rudder was completely in the water.
What am I missing? Shouldn't we have been close-hauled to sail at a point close the wind? Why was the nose pushing around to the N - and the boat not responding to the tiller?
