Making your own backing plates?
May 18, 2010
543
Oday 27 Gulfport, MS
I am trying to get up the gumption/knowledge on how to make backing plates with West System, etc type products. The link below describes what appears to be a simpler way than what I was thinking was required (--fiberglass mat layered repeatedly to form a rectangular shape). But this guy's technique looks much simpler and possibly strong enough for the job?
It was posted on a general boating forum, don't know by whom.
I was impressed with the creativity and how good his backing plate looks. Full description of his work and more pohotos at link below:
http://www.boatinghowto.com/f86/how-make-your-own-backing-blocks-seacocks-813/
Not how its described in the "Usual Suspects" of boating how-to books, but is this a reasonable method?
Thanks,
JQ
2,500
Oday 192 Lake Nockamixon
Check out Cap'n Pauley's article on backing plates in the current issue of Good Old Boat magazine.
I wonder if it's cost effective to make your own plates, or to just buy some G10?
Also, a glass fiber matrix does not gain strength from the resin. That's why we now vacuum bag laminates for maximum strength, rather than hand layup. For this reason, I would be more inclined to do my own woven roving layup with epoxy on heavy polyethylene sheet (for ease of removal.)
Keep in mind that chopped strand mat has polystyrene binding agents intended to dissolve when used with polyester resins. Although West Systems says you can still use it with epoxy, it won't wet out quite as nice as woven fabric.
Just my $0.02....
11,772
Not how I would do it as it is very resin rich and resin has little strength. Perhaps the easiest method is to simply use G-10 or GPO-3 pre-made fiberglass sheet.
Short of that wax a piece of glass, lay down some mat, roving, cloth etc. and build up the layers.. I can make a piece about 1/2" thick in 2X2, 3X3 etc. in about 15 minutes once you get everything ready..
This is what some of my home made sheet looks like...
Apr 8, 2010
2,252
Backing Plate thoughts
I have molded out some small parts with cloth and epoxy resin. Not having vacuum bagging means at hand I just put some plastic sheeting on top, some 1" foam, a board and about 30# (or more...) of weight. Seems to squish out the excess resin fine.
I found out years ago that for small jobs it was cheaper to just buy some G10/FR4 pre-made material, especially for stuff like flat backing plates.
For a project needing a right angle part, I bought the pre-made material from McMaster Carr. Nice guys to deal with and the price was right.
If I buy locally I even have a plastics supplier that will cut to my specs with their diamond-blade saw for no extra cost.
As Maine pointed out, there's no strength at all in casting something with resin with a bit of fiber thrown in.
Just my .02.
Loren
May 18, 2010
543
Thanks Brian and Maine. I'm hoping to replace at least some of my thruhull and thrudeck fittings this season--appreciate the course correction here. Regular hole saws and drill bits then?
Jonny
Brian-- I don't recall that in my latest GOB issue? Will dig through previous issue tonight in case its there.
Jun 6, 2006
6,990
is there something wrong with a piece of wood?
A good 3/4" piece of oak is what I use. home depot has them in stock and they are pretty easy to shape.
It does not hold the boat together and just needs to be able to take somebody standing on the thru hull and not break.
Apr 8, 2010
2,252
Wrong? No... but what with the chance of some outside water someday seeping in around the thruhull or some inside water (condensation, or whatever) slowly getting into the wood, it'll rot someday. Nice to do it the best way in the first place, IMHO.
Loren
I'm going to install a swim ladder on my runabout this spring. I weigh 250 lbs and all of that will pull on the ladder mountings. Any suggestions for backing plates? Oh since the bolts will have to be as low as possible on the transom to get two steps underwater, the backing plate will have little meat to the waterline side.
Nov 26, 2008
1,970
Endeavour 42 Cruisin
I take the piece of wood one step further. I soak it with penetrating epoxy, sealing out that moisture.
Aug 20, 2010
1,399
Oday 27 Oak Orchard
Mainesail has the same method I used to plug all the holes YOT accumulated over the years, Jonny. I used biaxials and epoxy for everything and am happy to report that everything is performing without problems. You may recall I was plugging above and below the waterline and incorporated a few nifty rabbets to seat everything. My mainsheet chainplate has a 3/16ths biaxial backing plate just for good measure and no cracks or otherwise.
Mar 26, 2011
4,031
Corsair F-24 MK I Deale, MD
What Mainesail said. There are many variations, all of them cheaper, faster, better looking, and stronger.
The only exception, for me, would be an area so curved I could not bed the FRP plate. In that case I simply hand lay some glass on the inside, perhaps including some prelaminated FRP as well. I've done this for bobstays.
Jun 6, 2006
6,990
Olson
Ok wood rots, Care to comment about wooden boats and their rot problems?
I mean seriously Olson. What kind of moron do you take me for? Of course you are going to water proof the wood.
11,772
Olson
Come to Maine and visit any of our wood boat shops and you will see they make a mint keeping these boats afloat. Six and seven figure rebuilds due to rot are not uncommon at all..
Just too bad the vast majority of boat builders never did that.. One of the biggest reasons I replace or re-install seacocks is not corrosion or wear but rotted wood backing plates...
BTW this is a $200K+ boat and the photo is recent... Think this customer got their 200K+ worth...? Bare Home Depot grade ply...??
Aug 16, 2009
1,000
Hunter 1986 H31 California Yacht Marina, Chula Vista, CA
What about using starboard for this application? Or is the problem that unless you use the special cement, you can't get the stuff to stick to anything?
11,772
Problem #1 very little strength, flexes easily.
Problem #2 nothing likes to stick to it.
May 18, 2010
543
... BTW this is a $200K+ boat and the photo is recent... Think this customer got their 200K+ worth...? Bare Home Depot grade ply...??
Thanks for posting that $200K picture, Maine...I feel a lot better knowing my plywood backing plates didn't cost that much!
Sprega
Sep 12, 2012
115
O,day 27 Brownsville Marina
A well designed, well built, well maintained wooden boat will have very little problem with rot.
Nov 9, 2012
2,500
So sorry, JonnyQuest, that article on backing plates was in the March/April (current) issue of Small Craft Advisor, not Good Old Boat. I get my 2 primary sailing mags confused from time to time :D Oh, and the article was about proper backing for deck fittings, not through-hulls. Sorry about that. Capt'n Pauley's main point was to taper the edges of the backing plate. He says Starboard cold flows under pressure. Maine says nothing sticks to it, which pretty much confirms for me that it is just a high modulus or ultra-high modulus polyethylene product.
Jan 4, 2006
7,836
Maybe .........................
.......................... if he was willing to spend $200,000.25, he might have received some decent pipe dope on the theads of the various pipe fittings. They're all leaking due to cheap brittle pipe dope.
If you suffer from obsessive compulsive disorder (OCD) as I do, you'll use 3-4 wraps of teflon tape followed by wiping the surface of the tape with Permatex #2 sealant on below waterline threaded pipe fittings.
11,772
By well built and designed and maintained does a Concordia count?
Other than some rotted frames and back bone this boat had been exceptionally well maintained by even the most critical wood boat standards..
This repair exceeded the cost of this boat when she was new, by a long shot.. Course if you can afford to own a Concordia...... A repair like this is probably like you or I buying a can of varnish..
